![]() | Home > Puma (Tdci) > Just doing same test...... |
![]() Click image to enlarge Perfect interactions from timer and remote!!!! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2682 ![]() ![]() ![]() |
o_O
what test is this? |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2153 ![]() ![]() ![]() |
...... Dgardel - I know you're Italian but this looks like a lot of Spagettii!!
![]() What are you playing with ?? ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
think the clue's in the Webasto timer and wiring harness .................
Yesssss
tested the "integrations" from Timer and remote control for the Webasto water Heater and all tests was OK 1. you can switch on from the timer and switch off from the timer 2. you can switch on from the timer and switch off from the remote 3. you can switch on from the remote and switch off from the timer 4. you can switch on from the remote and switch off from the remote 5. you can switch on from the remote and the timer switch off when the operating time is finished 6. you can switch on from the timer and the timer switch off when the operating time is finished you can set the operating time from 2 to 120 minutes Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
