Home > Puma (Tdci) > Heating - warmer on the left side when the heat is on
Simon.pl
Poland 2007 Defender 110 Puma 2.4 HT Keswick Green
Has anyone experienced this in his Puma?
The air is much more warmer on the left side of the vehicle (drivers side in my situation) than on the right one. I wouldn't mind it to be oposite as SWMBO like it hot, and I prefer not too Mr. Green
Is there anything that may be checked?
Thumbs Up
Post #518924 29th Mar 2016 6:29pm
This is entirely normal on the Puma and there is nothing practical that can be done about it.
Both the inlet and outlet pipes are connected to the left hand side of the heater matrix and as a result the left side gets considerable hotter than the right. The airflow through the left of the matrix exits predominantly through the left vents, which are therefore hotter.
LR did release a modification mysteriously for LHD vehicles only which blanked off the left-most inch or so of the matrix but not only does it not make much difference (apparently) but also requires the complete removal of the dashboard to install.
Post #518943 29th Mar 2016 7:16pm
Get a td5, you won't have this trouble!!!
Post #518954 29th Mar 2016 7:30pm
Simon.pl
Thanks Blackwolf - will have to learn to live with it or use the gaffer tape instead Rolling with laughter
Thumbs Up
Post #518960 29th Mar 2016 7:35pm
ericvv
Simon, here is your gaffer tape solution as suggested by JLR. Thumbs Up
https://www.defender2.net/gallery/albums/u...er_fix.pdf
If you still think about it, then have a look at this older thread with a clear picture by AndrewS about how easy it is to remove the dash...
http://www.defender2.net/forum/topic1090.h...p;start=15
After seeing that, I decided that in this case I could accept the standard dealer phrase that "they all do that, Sir". Laughing
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #519010 29th Mar 2016 8:26pm
Simon.pl
Quite surprising solution Shocked It's a pity they didn't issued something like "if it is too hot, just don't use heater system" Laughing
The time of the dash removal will come sooner or later - I want to retro fit electric windows, central locking system and will probably exchange the alarm unit + have no audio at the moment and the dash makes annoying noises when driving ++ will have to try to make this car a little more quite and warmer, so yes - will start mentaly prepare to dash removal Mr. Green
But after seeing the JLR fix I doubt I will give it a try..
Anyone tried it? Shocked
Thumbs Up
Post #519075 29th Mar 2016 10:22pm
I have another cunning plan which I will hopefully one day get round to trying, which is to insert a length of copper tube into the inlet pipe to the heater matrix so than the hot water is delivered to the upper right corner instead of the upper left. My theory is that this will result in.more uniform temperature across the matrix.
I also intend to modify the airbox so that the direction centre dash vents discharge unheated air since I don't like warm air at face level.
Post #519087 29th Mar 2016 10:43pm
Simon.pl
So you mean you would like to stick it far to the right so the water starts flowing from the "end" of the matrix instead of the connection point of the pipe and the matrix? The JLR solution is to shorten the way a little or am I missing something?
Post #519093 29th Mar 2016 11:12pm
