![]() | Home > Technical > Handbrake 'double pull' to get it to work |
Stricko,
is it the 2010MY Black one as noted in your 'signature'? if so could it be it needs the hand brake recall to be carried out - this is where box oil can leak onto the back brake? if the shoes are clean then so far as I'm aware the brake works very well - the only common issue I'm aware of is the shoes rubbing but wouldn't think that has anything to do with what you've mentioned unless some how something has glazed over as a result of the rubbing? good luck with sorting it out. If it's an early 2010MY I'd have expected it to just about be sorted by now. Mine was a late 2010MY and I think it's just recently all got sorted. ![]() |
stricko Member Since: 30 Nov 2015 Location: East Sussex Posts: 120 ![]() ![]() |
Thanks Caterham
Yes it is the 2010MY one. Do you know the recall number? I will try and check it out with a main dealer to find out as I dont have any record of any recalls done. I am the second owner. The problem could also be described as the cable feeling like it stretches when you do the first pull, then there is a bit of slack to take up again when you do the second pull. This happens when it is on the flat as well as on a slope. Not sure if that would be the same as the issue caused by the problem you describe above, however I will definitely look into it. Thanks again --------------------------------------------------------------- |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17885 ![]() ![]() ![]() |
Not normal at all, the supplier is giving you the brush-off.
not wanting to bore you with the problems I experienced but you could try this....
on the flat apply hand brake and determine how far the leaver moves. drive forward a short distance - say 0.5 mtrs and apply hand brake and not how far the lever moves. mine would move varying amounts as the output flange wasn't true and hence the drum was oscillating. not only was the hand brake variable but most importantly I couldn't adjust the hand brake properly and would always rub slightly causing other issues. New flange and all sorted. ![]() |
Agreed. I would say the ratchet or other part f the operating mechanism could be sticky as opposed to oil on the linings as per Caterham's suggestion. The latter is more likely to cause the brake to slip when applied or even bind when in motion. Steve.
Thanks everyone for the replies.
I will drag myself away from my work later and go outside and try and establish a pattern of what happens. Is a new flange a big/expensive job? --------------------------------------------------------------- |
new flange is a doddle - even I managed to replace it (albeit with some guidance) and it's been ok since.
cost - If I recall the cost for the full kit (ie flange, lock nut, felt washer etc) was about £100. my memory aint the best so might be worth checking that cost. Also I seem to recall there was a loss of some oil so be prepared to top up if you carry out this procedure. ![]() |
