Home > Off Topic > MOT Changes in 2011 Heads Up
pom
HID lights – Specifically those aftermarket kits that give the very bright headlight beams. Any cars found with these kits will be an automatic MOT failure. Testers are able to easily spot the difference between HID kits, and manufacturer fitted Xenon’s. Easy to spot as Xenon cars have suspension level sensors, in car beam adjuster, and usually headlight washers.
Chipped ECU’s - Unsure of just how/if this one will realistically be enforced, but any cars with chipped ECU’s will in theory be an MOT failure. I can only assume VOSA have found an easy way of checking ECU software through the cars OBD port (diagnostic plug).
Wiring harness – The general condition of he wiring harness will be checked to make sure there is no rubbing or chaffing, and that the harnesses are in generally good condition. If unsecure, or damaged again MOT failure.
Airbag warning lights - If any warning lights are illuminated, it will again be an MOT failure.
The above was confirmed in the October 2010 VOSA newsletter. Which can be viewed as a PDF from their website. Link below, see page 8 for details.
http://www.dft.gov.uk/vosa/repository/MoT%...202010.pdf
Pom
edit: link fixed
Post #51847 8th Jan 2011 9:19pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Link don't work ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #51851 8th Jan 2011 9:28pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Would be good to hear from Pete Bell on the chipping thing? He will know how they plan on seeing if they are chipped and what can be done about it.
Pete.
Post #51870 8th Jan 2011 9:54pm
ickle
Page 9 points to incompatability of bulbs/light units & illeagle chipping of engines as something for future thought - have I missed the article?
Post #51871 8th Jan 2011 10:00pm
