Home > Puma (Tdci) > Disable alarm and keep central locking
dmohil
Hi, I want to disable alarm and immobilizer and only use the fob for central locking on my 2011 Puma.
This seem to be easy with use of Nanocom. But when disable the alarm the central locking won't work. I must have arm on lock enabled to have central lock working.
On my TD5 it works as I want with same configuration.
Any idea of what it can be?
Post #518338 27th Mar 2016 10:21pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
i think I'm correct in saying that locking it using the key, deactivates the internal sensors, but leaves the perimeter sensors active. Must be opened using the fob to deactivate the alarm. If that's of any benefit? 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #518340 27th Mar 2016 10:29pm
HardCharger
I thought you couldn't do that? The manual says that if you lock with the key, you unlock with the key, if you lock with the FOB then you unlock with the FOB. Locking with one and opening with the other sets off the alam and you'd have to do the cryptic ceremonies of entering the EKA, if memory serves.
Disabling the immobilizer shouldn't affect the central locking. I'm not sure if you can really disable the alarm though.
So am I correct in understanding that the OP's purpose is just to have remote central locking and no alarm and immobilizer?
Post #518349 28th Mar 2016 4:50am
dmohil
Yes that is what I want. I have disabled this with my Nanocom. In the manual it is described and the central locking should work.....
Post #518353 28th Mar 2016 6:18am
gcc130
I lock mine manually when the dog is inside and always open with the fob. Never had any problems.
Post #518437 28th Mar 2016 2:09pm
