Home > Technical > Twisted Friction Plate
Grenadier
This follows on from my continued clutch problems. Dave at Ashcroft Transmissions, thinks after my lengthy email, that it might be a twisted friction plate (on assembly) causing drag.
Anyone know what that means, what to look for, what can be done about it?
Ta Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #517266 24th Mar 2016 8:50am
familymad
Twisted as in bent or as in a Twisted branded plate? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #517270 24th Mar 2016 8:55am
Grenadier
bent Monsieur Le Grenadier
Post #517275 24th Mar 2016 9:09am
Watch this:
Before you whip the gearbox out to check the friction (also called driven or clutch) plate you should check out the issue is not caused by:
1. lack of hydraulic fluid
2. air bubbles in the fluid
3. oil contamination
4. a worn or faulty hydraulic system
Your clutch plate may not be straight and so not disengaging fully as shown in the photo - or as others have said on other thread - maybe it's in the wrong way around - not seen a Puma one to know the difference:
Failing all that I guess if you have the gearbox out again it may be worth checking:
1. the flywheel friction area is clean and free of any deposits
2. flywheel is not warped
3. clutch cover is not warped
Post #517314 24th Mar 2016 10:46am
Grenadier
Thanks Supacat. Thumbs Up
Heading off to garage shortly... Monsieur Le Grenadier
Post #517317 24th Mar 2016 11:02am
