Home > Puma (Tdci) > Egr strange noises
Flyingfocrs
Scotland 2011 Defender 110 Puma 2.4 USW Santorini Black
Egr strange noises
So for the last year or so my EGR has made the distinctive Chukka Chukka Chukka on shutdown.
Then it went quieter for a while, which I put down to the car approaching service time and older oil.
Oil and filter were changed and now it makes more of a muffled lazier chuff chuff chuff on shut down but also it is also making the same sound but only once everytime the clutch is depressed.
So is this the sound of impending doom?
Post #517005 23rd Mar 2016 12:26pm
RED-DOT
I fitted a new one some 2,000 miles ago and it's silent. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #517006 23rd Mar 2016 12:32pm
hornet
What do you mean with "silent"? In any case it should perform cleaning cycles after switching off. Whats the brand of your EGR?
Post #517012 23rd Mar 2016 1:09pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
"impending doom"
Mine's the same: the normal chucka chucka chucka on switching off now occurs occasionally when driving, more so when - as you describe - the clutch is depressed. I'm of the si fractum non sit, noli id reficere school, i.e. I wait until something physically breaks, then I know exactly what to replace.
But can an EGR failure cause other problems, perhaps a breakdown? What's the worst that can happen?
Peter
Post #517014 23rd Mar 2016 1:10pm
hornet
Multiple failures if the EGR does not close completely. In my opinion one of the most malicious parts. RTFM.
Post #517023 23rd Mar 2016 1:27pm
The EGR if it has issues should flag up the MIL Amber light on dash.
If it does, it may go off.
Ultimately at some point though it will come on and stay on which is an MOT failiure.
If the EGR gets stuck closed everything will be fine but you'll have the MIL on all the time which you can't have permanently. mind you it could also mask any other problems too.... If they should arise.
If the EGR gets stuck open it'll do the above and be in limp mode and will have awfully poor performance and possibly engine damage if left.
Mine shut down, re-mapped and blanked.
Buy a few EGR's and counter in the work and you've got a remap paid for and I've never had a squak from mine since thank god. (Pardon the pun)
They also have the tendancy to make the engine sound and run like crap and the performance is rubbish.
Also can use much more fuel.
I've tried to look for the WSM page regarding the bolt torques but can't seem to find it right now.
Post #517030 23rd Mar 2016 1:39pm
Cupboard
Good luck getting a torque wrench in there!
At the least they will flag up a load of MAF related errors, as I've found.
Post #517033 23rd Mar 2016 1:50pm
Birdy
So, keep on keeping on...
... until a warning light comes on. Cheers, mind at rest.
Peter
Post #517063 23rd Mar 2016 4:24pm
I got a torque wrench on mine, the lowermost bolt is the most difficult though.
Post #517083 23rd Mar 2016 6:31pm
Flyingfocrs
Must confess i've thought the economy has gotten a little worse recently as well.
Looks like a new EGR will be getting ordered then.
Post #517113 23rd Mar 2016 8:14pm
It can cause MAF codes to flag up electronically once checked also can affect general performance.
I would say from what you've mentioned you've had the same scenario as I had.
'EGR stuck closed'
New Genuine is are �160 which is ridiculous. Rolling Eyes
Post #517114 23rd Mar 2016 8:19pm
hornet
[quote="custom90steve"]
[/quote]
This is what I also totally recommend. VW had the same idea... :thumbsup:
[/quote]
There exist M8 and M6 screws, manual says 23/10 Nm
Post #517257 24th Mar 2016 8:05am
'EGR stuck closed'
Is EGR stuck closed an issue or likely to effect performance?
Is it not just stuck open that's an issue?
Post #517304 24th Mar 2016 10:09am
Hornet - Yes, that sounds correct. I know it's in the WSM but I don't have easy access to it on the Tablet.
Supacat - Well EGR 'stuck closed' is likely to be less of an issue and may even partially increase performance as its effectively blanked.
However, due to it not being shut off electronically it will be sending fault signals and thus effects the rest of the whole system in. Particular the MAF sensor.
It can put various readings about and still affect performance. (Plus MIL)
However, EGR 'stuck open' is much more of a worse issue as exact gasses will be exiting through it permanently which is never supposed to be permanently.
It will do all of the above and so I've heard have a heightened affect on performance and may even result in breakdown or ending up in a dangerous limp more situation.
As I mentioned above, the fact that Genuine are now �160 each for these and that is providing that you replace yourself a few of them and you've got a good tune for yourself that gives you other benefits too.
A tune would render it obsolete permanently and blanked, mine has been two years now no problem from Alive.
My EGR now is still faulty but because it's shut down it doesn't even matter.
I hate to so think what stealers must charge for supply and fit of them inclusive?
Post #517319 24th Mar 2016 11:12am
P.S. If you did always secretly want a tune, now would be your excuse to "fix" it to your OH / Wife. Rolling with laughter Bow down Whistle
And explain the slightly more expensive permanent fix.
Ped finitely recommend Alive though. Thumbs Up
Post #517321 24th Mar 2016 11:14am
