Home > Puma (Tdci) > Tdci puma Aircon Evaporator
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
Hello,
Appreciate if someone could tell me the part number just for the evaporator (Chiller) for RHD defender puma tdci for my aircondition. If anybody know where i can buy just the evaporator, that would be great! . The microcat says the heater - RHD manual aircondition as a whole unit and the part number is LR031513. Cheers Very Happy Very Happy
Regards,
Diluk
Post #269506 26th Sep 2013 6:06am
Gilson Nayrdo
Brazil 2009 Defender 110 Puma 2.4 CSW Galway Green
Hy,
I appreciate if someone could tell me the PART NUMBER just for the EVAPORATOR for LHD Defender 2.4 - PUMA - 2009 - for my air conditioning.
I have searched all websites and I have not found. Bow down Bow down
If anybody know where I can buy just the evaporator, that would be great!
Best regards!
Post #516939 23rd Mar 2016 1:19am
dilukabey
I guess LR don't sell the aircon evaporator as a separate unit hence they sell it as a whole set including the plastic casing which will cost you a lot (may be it's cheap pls check) . Best thing to do would be to find out a second hand set or look for a possible alternative evaporator of any other make which could squeeze in to you existing unit. Appreciate if anybody can further elaborate this.
Post #516993 23rd Mar 2016 10:51am
Gilson Nayrdo
Hello! I'm concluding that the market parts and Land Rover do not sell this evaporator alone. I do not understand why, I found evaporators other Land Rover models for sale. Thank you, Dilukabey.
Post #517025 23rd Mar 2016 12:30pm
dilukabey
I recently replaced mine with another brand and had to cut inlet and outlet pipes and modified to suit the defender casing.
Post #517268 24th Mar 2016 7:52am
dilukabey
recently replaced mine with another brand and had to cut inlet and outlet pipes and modified to suit the defender.
Post #517289 24th Mar 2016 8:38am
Gilson Nayrdo
Hi,
I bought a whole new box for the air conditioning.
what brand you replaced?
Thanks!
Best regards!
Post #517358 24th Mar 2016 12:12pm
HardCharger
Unfortunately, Land Rover and any other aftermarket vendors do not sell the coil alone for some reason and you will have to get the entire plastic box.
If you know shops who can make coils, you could provide yours as a sample and have one made but make sure it is laminated for longevity. Much cheaper than buying original and you get the same performance. This is the route I took and am happy with the results. I even had the coil slightly enlarged to help deal with the hot weather and humidity we have where I am at the moment.
I hope this helps.
Incidentally, is there really a difference in the coil from a RHD unit and a LHD unit?
Post #518350 28th Mar 2016 5:27am
Gilson Nayrdo
Hi,
Thnak you very for your opinion.
I think there is difference in the coil from a RHD unit and a LHD unit.
I have a LHD.
Best regards!
Post #518475 28th Mar 2016 4:22pm
