![]() | Home > Puma (Tdci) > Oncoming lights reflections |
Simplified version of the law:
https://www.gov.uk/government/uploads/syst...irrors.pdf ![]() |
Applying a tint will actually make the situation worse due to the reflective properties of the film applied which are greater than the glass without a tint. The issue on mine was finally eradicated with the fitment of a 'tinted glass' (not an applied tint) rear safari door window. If you go through life with your head in the sand....all people will see is an ar5e!!
Having not been able to see anything at all at night through my rear view mirror with tinted film windows a VGS rear window vastly improves the situation and IMHO is much better than standard with no tint at all. If you go through life with your head in the sand....all people will see is an ar5e!!
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 626 ![]() ![]() ![]() |
Excellent, thank you.
