Home > Technical > Clutch - ongoing
Grenadier
Clutch - ongoing
Hello, all. For those of you who might be perusing the site whilst staying up to wTch the Aussie GP, more clutch questions please. Following on from previous threads, the clutch has been fitted, master cylinder replaced, system bled and finally managed to get the beast started. However, for love nor money, we cannot get clutch to engage properly. Reverse and First impossible, the remainder difficult and gratey. If that's a word. Any thoughts, before we delve back in? And assuming we have to delve back in, we're thinking Slave Cylnder (also new), but could it be anything else?
As a reminder it's a Puma 2.2 with standard 6-speed gear box. The clutch and slave were AP supplied by Ashcroft Transmissions. Nothing new, alternative, hand built or heavy duty. Like for like. Approx 70km on the clock.
Tips as always welcomed, I'm off to watch the England GS match now.... Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #516030 19th Mar 2016 8:17pm
bob neville
Try adjusting the clutch pedal travel, exactly the same procedure on a TD5 and Puma.
Do an internet search on TD5 clutch pedal adjustment and all will be revealed Thumbs Up
My thread from six years ago about a similar problem
http://www.defender2.net/forum/topic3604.html?highlight=clutch
2013 Defender 90 CSW - sold
Post #516037 19th Mar 2016 8:34pm
dorsetsmith
Post #516040 19th Mar 2016 8:38pm
Morepower
New Zealand
Yes... Sounds like clutch adjustment... I had to do mine after the dealer replaced my 110 clutch under warranty... The truck was almost un drivable...
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #516126 20th Mar 2016 9:12am
Grenadier
Thanks for the answers. I should have said that the MC was replaced only after we first tried the new clutch and we suffered from the impossible R/1st and difficult 2/3/4/5/6. Should we still look at the travel or will that not make sense if the problem occurred both before and after the MC was replaced?
Thank you Thumbs Up Monsieur Le Grenadier
Post #516128 20th Mar 2016 9:19am
bob neville
Yes !
You are going down the exact same route my dealer did, replace everything and in the end it was the adjustment that caused the problem.
It is not a long job.
Post #516148 20th Mar 2016 10:42am
miker
I put my clutch plate in backwards once, same symptoms
Post #516187 20th Mar 2016 4:43pm
Grenadier
bob neville wrote:
Yes !
Bob
Thanks Bob.
PS, Miker, is putting in the clutch plate backwards even possible? My mech has 20 years experience, albeit this is his first Def. But I hope he'd spot a back to front clutch... Whistle Monsieur Le Grenadier
Post #516229 20th Mar 2016 8:13pm
srod
Yes it is possible to get the friction plate the wrong way round, and I can see how it could be very easily done given the way a new clutch kit comes packaged...
Post #516240 20th Mar 2016 8:51pm
bob neville
I agree with all the comments about putting the friction plate in the wrong way round, my local Indie has had the same issue with Ford engined Defenders.
Post #516244 20th Mar 2016 9:12pm
miker
Admittedly mine is a TD5, but yes it's possible, and yes it all goes back together!
I've been fiddling with cars since I was in nappies, and my dad has been a mechanic for longer than I've been alive! We both looked at it, both vowed to look it up, both forgot! It had no markings on it either...
Post #516305 21st Mar 2016 12:20am
Grenadier
Thank you all. Fingers crossed the pedal adjustment is all that's needed..... Whistle Monsieur Le Grenadier
Post #516322 21st Mar 2016 6:52am
