Home > Puma (Tdci) > Help with 2.4tdci smoke
Page 2 of 3 <123>
Eduardo
That was my next question...
What about the coolant level? Eduardo
Post #515833 18th Mar 2016 9:06pm
dannyc85
United Kingdom 2007 Defender 90 Puma 2.4 CSW Stornoway Grey
If I start it and drive off straight away it smokes. If I start it and leave it running in the drive for 15 mins it stops smoking but smokes exactly the same when I start driving. This is what was pointing me towards turbo as the turbo operates only over a certain rpm ( I might be wrong). Mpg is terrible it always has been but is definatley using more fuel since this problem started
Post #515843 18th Mar 2016 9:34pm
dannyc85
Coolant level is fine as well
Post #515844 18th Mar 2016 9:35pm
jst
if it was the turbo would it not always be there?
so too much fuel coming in but only when sat idling/not under boost? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #515846 18th Mar 2016 9:42pm
dannyc85
I thought the turbo only operated after a certain rpm? I have had the injectors replaced it was far worse before I had them done. Any thoughts on this idea from the transit forum that the turbo seals are faulty causing the oil in the intercooler etc
Post #515872 18th Mar 2016 10:24pm
dannyc85
Post #515874 18th Mar 2016 10:25pm
Way of life
Canada 1985 Defender 110 Puma 2.4 CSW Santorini Black
I'm watching this mine is doing the same thing after cleaning the injectors and new fuel pump.
Mine is just like yours doing all the same stuff.
Good luck i hope you get it fixed, so mine will be fixed.
I'm going to do a BAS remap and reset the Fuel pump volume control valve (VCV) programming and the Engine pilot correction learning procedure. I'm going to do this in about 2 weeks when I get home.
Good luck
Post #515913 19th Mar 2016 4:28am
jst
if the engine is running turbo is turning although not doing much at engine speeds to enhance the amount of air in the chamber
if its overfuelling at low rpm you would be wasting fuel and hence white smoke until the turbo is coming into boost and using that extra fuel
if its oil your oil level would be dropping over time which its not.
from the description it sounds like a lot of oil being burnt
over what time period/mileage has this been happening? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #515918 19th Mar 2016 7:58am
dannyc85
It has happened over the last 3 months no more than 2 thousand miles. It was really bad at first but then I had the injectors replaced. Its confusing that it happens only for the first half a mile or so then will run fine all day.
Post #515943 19th Mar 2016 11:17am
spudfan
Ireland
Does'nt the tdci like the td5 have some programming to deal with unburnt fuel left in the system from a previous trip. Maybe this has gone awry and it's a problem with the ECU programming. Just a thought to add to the many others given here. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #515974 19th Mar 2016 2:53pm
jst
injectors still leaking into the cylinder which is why is diesel not oil, nothing in coolant, and why its goes after initial startup but comes back after being left for a longer period - ie over night. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #516248 20th Mar 2016 9:37pm
dannyc85
I have had all 4 injectors sent away and inspected. 1 was faulty. Iv replaced them with all new copper seals ect. Would the diesel burn off after 5 minutes of idle? This smoke is happening after idle whilst actually driving off.
Post #516346 21st Mar 2016 10:10am
Mogboy
Australia 2007 Defender 110 Puma 2.4 SW Belize Green
White smoke is raw diesel coming through. Injectors checked OK, so there are a couple of other things to check...
COMPRESSION: if low will white smoke until it warms up. Most likely reason is gummy rings. A high quality flushing compound, or multiple quick oil changes might do it.
INJECTION TIMING OUT: Worn keyway on timing gear was common on older technology diesels. CRD computers decide the timing based on crankshaft position and other inputs. Could crankshaft position sensor have moved slightly?
Gummy rings is the more likely.
Good luck
Mogboy
Post #516650 21st Mar 2016 11:36pm
dannyc85
Thanks Mogboy il have a look into it this weekend.
Post #516714 22nd Mar 2016 10:49am
jst
But it doesn't do it after cold starts later on in the day and drives normally
edited to change child to cold! Sorry - phones! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #516851 22nd Mar 2016 8:49pm
Page 2 of 3 <123>
