Home > My Defender > Paint removal
gilly1969
Paint removal
My Defender 90 should be coming back from its recent trip to the welders this weekend. Next phase in the restoration process is to prep it for respraying. It has at least 3 different layers of peeling paint and I was thinking of getting it blast cleaned back to bare metal, but I'm worried the process could be too aggressive leaving me with a pile of aluminium Swiss cheese. Am I better just to get it rubbed down and prepped by the bodyshop?
Post #515428 17th Mar 2016 8:05pm
mk1collector
A good quality paint stripper works wonders then sand of what remains. Ray
My build thread
Post #515478 17th Mar 2016 9:07pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
Don't have the aluminium panels blasted, it will stretch and warp them.
As already said, paint stripper would be the best option.
Post #515483 17th Mar 2016 9:15pm
gilly1969
Thanks for the heads up. The guy I spoke to seemed to know his stuff giving me the impression he'd 'media cleaned' several Land Rovers in the past. He even explained how to take it apart. Maybe you're both right though. As I'm replacing all of the doors and the bonnet anyway, I could just invest in an orbital sander and some elbow grease to save myself a few bob. Out of interest, what's the most effective paint stripper?
Post #515498 17th Mar 2016 9:32pm
gumdrop
Soda blasting - not as aggressive as grit see Frosts website or Google Millar Soda Blasting. Cheers
Simon
50th D90 - my toy!
Freelander SE Td4 3 door - local run around
1958 Series 1- Rag top!
Post #515522 17th Mar 2016 10:04pm
db950
Here is a quote from another thread of some stuff recommended.I've never used it, I just sanded mine but wish I'd heard of it before!!
Defender_Td5 wrote:
Hi Steve,
Thank you for the praise. I put a lot of thought and planning into how exactly I wanted to put this one together and after the previous rebuilds I had done, I learned a lot about how to do it the right way! I wanted to build a vehicle that didn't just look good, but was built to last and be used for what it was intended for.
The company that supplied the paint stripping solution was called "Strippers Paint Removers" they can be contacted on 01787 371524. Here is a link to their website:
http://stripperspaintremovers.com/view_products.htm
To completely strip a Defender 110 of all paint (I mean both sides of the panels) I used around 25L of stripper. It is not nice stuff though and will burn through household rubber gloves in no time! I ended up putting on two layers of really thick industrial cleaning gloves.
Rob
Post #515529 17th Mar 2016 10:09pm
gilly1969
Thanks for the advice. Putting my environmentally responsible hat on, soda blasting sounds like a good option. I don't have a yard or workshop to work in so the problem I have with a chemical removal process is that I'll be swilling rubber eating paint stripper straight down the drain! I'll keep you all posted.
Post #515676 18th Mar 2016 11:24am
gumdrop
Talk to Michael Miller http://www.millarsodablasting.com/ - I bought my blaster off him. I got the dual version grit and soda - so far so good blasted ali and also a timber dresser - no steel as yet - you have to play around with pressure but once you get it correct works really well. He also does contract work his place hd a Jensen, Porsch and Beetle body shell in it. For all concerned I have no connection with him - just a really helpful guy Smile Cheers
Simon
50th D90 - my toy!
Post #515697 18th Mar 2016 12:30pm
gilly1969
Thanks Simon. Now weighing up cost of buying/hiring equipment to do a DIY job versus sending it away to be done.
Post #515739 18th Mar 2016 3:30pm
CY88
1986 Defender 90 V8 Petrol ST Keswick Green
Having done this recently on a car with 3 to 4 layers of brush applied paint, the soda blasting that the paint shop first attempted was not as efficient as the stripping solution that they resorted to. Depends on the type of paint that you're trying to remove though.
Post #515750 18th Mar 2016 4:02pm
