Home > Camping, Caravanning and Holidays > Pull out canopy side or rear without a rack?
Stacey007
Hello
Without a roof rack is there such a thing as a pull out canopy either long ways down the side or over the rear door?
I've seen the type on a VW T5? seems to attach to gutter. would that work?
Thanks
Post #515547 17th Mar 2016 10:40pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
I've got a Fiamma F35 Pro on the side of mine but I made brackets up to go onto the LR rack.
You could make some gutter mount brackets, the Fiamma is held on by a standard caravan awning rail so you can just buy a screw on rail and make brackets up to suit. I don't think they have a gutter mount suitable to buy, they are all bespoke to different vans, although they do have a kit to fit onto just roof bars.
Have a look here,
http://www.agentfiamma.co.uk/fiamma-f35-pro-awning-Adapters/
Post #515610 18th Mar 2016 12:49am
dantastic
Depending on how often you plan on using it this might be an option
http://www.ebay.co.uk/itm/Car-Back-Awning-...Sw9N1Vlfi-
I imagine not as quick as a pull-out one but it is cheaper, covers a larger area than a pull out one and, attaches to the vehicle without having to bolt anything on. If you're only going to use it a couple of times a year I think it would be great.
Post #515646 18th Mar 2016 9:42am
LittleFoot
We are actually working on a set of gutter mounts for our awnings Smile
Post #515647 18th Mar 2016 9:57am
