Home > Maintenance & Modifications > Sat Navs
chay
Wales
Sat Navs
Has anyone 'plumbed in' a sat nav into a 2.4tdci Defender, with the new dash? I saw one recently that just had a inch of cable from the back of the dash to the sat nav holder on the windscreen, very neat and tidy.
Any advice appreciated.
Regards
Chay
Post #5125 29th Nov 2008 6:14pm
mse
Are we talking an in dash one with a motorised screen out of the stereo or are we talking like the SVX a Garmin (tomtom etc) on a fixed mount with a hardwired connection. Mike
Post #5129 29th Nov 2008 7:42pm
chay
Wales
No, just a Garmin on the windscreen, but wired from out of the rear of the dash.
Post #5144 30th Nov 2008 11:09am
mse
Cant see that being a huge problem.
2 ways, get a normal 12v garmin cable, or get one of the ones they used to do which doesnt have a socket.
Take it down to (as i would do) its own 12v source or to the 12v socket and wire it in there. You will have to drill a small hole i expect - get a gromet the size of the cable and make the hole to suit. You will also probably need a 90 degree drill adaptor to get the drill into position without removing the dash. Mike
Post #5145 30th Nov 2008 11:41am
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
Just to say my 2nd hand Defender came with a wire and plug sticking out the top centre of the dash, just below the windscreen, just as Chay has seen. I presume this was to power the previous owners Satnav or phone etc...
There is no cable hole drilled - it just tucks down the back of the dash in a similar way to the heated windscreen feeds. Also there are no other drilled holes, so whatever it was powering must have been suction mounted.
I would like to use this myself, but it doesn't fit my Garmin Nuvi.
I will probably be replacing my Satnav within the next few months as the maps are way out of date, (and it seems to be a similar cost to buy a new unit than to buy new maps!) - it would be good to get one that can use this plug...
My current Garmin has a mini USB type of connector - the one sticking up is like a laptop plug (the small hollow tube type) - does anyone know if TomTom or any other Satnavs use such a plug?
Or if it is possible to get an adaptor?
Post #5148 30th Nov 2008 12:55pm
red Defender
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Bonatti Grey
I have done what you are talking about. The power cable for my Garmin 276C comes through a hole I drilled in the top of the dash and is hard wired to a multi cigarette lighter socket I fitted to the side of the console in the passenger foot well. It is easy to remove the the front of the centre console, just undo the 2 screws in the front of the centre console and use a wide blade to pop the whole thing forwards. This gives access to the area behind and routing cables becomes quite easy.
Best of luck. Thumbs Up Whats broken now ?
Post #5152 30th Nov 2008 4:23pm
chay
Wales
Many thanks for the advice, you must be right as my chum now tells me that Halfords charge £39.99 for doing the same thing, so it must be both easy and take less than 10 minutes!
Post #5154 30th Nov 2008 5:01pm
Grockle
You need to fit a cigar lighter behind the dash to power the nav,you can't just cut the end off the lead and tap into a feed. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #5729 24th Dec 2008 10:53am
chay
Wales
Many thanks for that piece of advice, maybe that's what Halfords charge the £40.00 for, the extra cig lighter....
Post #5758 26th Dec 2008 5:59pm
