![]() | Home > Maintenance & Modifications > Overland Set Up |
| ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517
tack...i reckon that system looks ace (and somewhat affordable
couple of questions please... 1. where do you get the tarp/awning jobbie from? 2. as for the oztent poles, where/how much? looks good and a somewhat flexible design approach...i like it btw...all round a nice looking truck/set-up al |
| TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715
check this out.... http://uk.oztent.com/products/default.asp?CategoryID=2
Also Brendan will be able to help you out as well....
http://www.4x4overlander.com/products/camping/ |
| driver Member Since: 02 Aug 2009 Location: bude , cornwall Posts: 206
The Army basha/tarp you can get from any good army surplus store RVOPS is the one I use or from that well known bidding site, expect to pay about £30-35 pounds for a genuine one which are designed to use as a stretcher as well so are very strong, you can get a jungle one which is green but lighter material the size of mine is 3m x 2m from a company called bcb, hope this helps.
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
Chris and TJ of Boab are currently in Morocco leading one of their raids. They are back about 21st Jan. At the risk of getting into trouble, if anyone wants help getting hold of Oztents give me a shout Cost off top of head for a pole is £12.50-13 each Brendan |
cool...
thats the uprights and crossbar priced up. wonder if that side awing is one or two sections, is it designed to work the same as tacks |
guys...
i won't mind some more tips/knowledge, regarding overland set-ups... pics would be cool cheers al. |
c'mon chaps........roll up ROLL UP now....
http://www.defender2.net/forum/topic4982.html?highlight= |
| BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253
A tarp from decathlon would so the same thing, poles included in it.
or for more flexibility, get a 3M/3M Tatonka tarp and two/three adjustable height poles. Just use carabiners to attach to your rack (fast to put up/take down). All you need then is some nylon cord or 2 mil dyneema (para cord soaks up water and is weak) as guys, use taut line hitches for them and you're away. Absolutely max cost, a hundred quid. You can keep it high to keep sun off in calm conditions, bring it down low and tight when windy and raining, a fantastic bit of kit to mess about with. I'll take a pic of mine and post it next time I use it |
| wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2154
Just as a comparison. We’ve got a Brownchurch full 3 sided awning that is really fab to use! Its very strong and built to last.
Also got a porch awning that can sit just about anywhere on the wagon - but we normally have it over the back - cost about £60 and is really easy to put up as its built like an umbrella! See my gallery for overland set up as a Dormobile and the awnings ... We’re planning some overland trips this summer to Holland Germany Denmark & Sweden as well as our normal ones all over the UK so the awnings will be well used ….. probably in the rain …!! Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
Al there is no one right way of setting up an overland vehicle.
Your needs might be completely different to the next person. There is a lot of gear on our red 110 we will not recommend to the average traveller. There is nothing wrong with the gear but since we tend to do long trips as a solo vehicle sometimes in remote areas we have long range fuel tanks, twin winches, rear axle lockers etc. For the average traveller doing a 3/4 week trip in convoy then they do not need that level of equipment. They may want it, they may be able to afford it but do they need it? Doing a two week tag along tour to Morocco is a lot different to a solo trip across the Simpson Desert The basic requirement is a mechanically reliable and well maintained vehicle. Sort that one out first and foremost. Remember weight is the enemy of the overland traveller Find vehicles which have been 'there' and talk to their owners. Check out the experience of the owner. Are they wet behind the ears and just bought a vehicle with all the goodies already bolted on? On forums check out the credentials of people giving advice (Including me!) I come across one guy giving lots of advice. His experience? Zilch! He had done his research When you first start looking at gear at shows leave your cards at home! That way you might not be tempted to rush in and bling your vehicle with gear you don't need. Try and find out the experience of the people on the stands as well (Might be difficult at a busy show, but a bit of prior research??) Prepping an overland vehicle is a slow evolving project and how you prep it for one trip can be different to the next trip but the basic requirement stays the same. Mechanically reliable vehicle! Brendan PS Have I got any experience? Have a look HERE and HERE and you decide |
The awning we use
Click image to enlarge Barbara loved the concept from the start. I had my reservations about it. Had more reservations when on a very still day I managed to turn it into a big kite. This was down to my fault in being lazy. Since then have used it in Scandinavia and the UK in very wet and windy conditions (55mph at Manby) Yes it is a great bit of kit as long as you are not lazy deploying it and deploy it properly. Price wise it can not compare with a tarp and a couple of poles However it is much larger and price compares favourably with other commercial awnings especially when you consider the size and shape of it. HTH Brendan Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
The voice of sanity speaks |
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
Only problem is there are also some people with lots of experience that also talk complete Most to be fair at land rover shows. Mike |
