![]() | Home > Technical > Wolf 24v electrics |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8329 ![]() ![]() ![]() |
reliable in my experience, could always be changed to 12V easily Cheers
Wolfs are really easily maintained, the electrics are the same as reliable as any other. As said it can be swapped to 12v if you want.
I shall send you a pm ref what they need to run. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
Thanks, jst and Mash. Thanks Mash would like to see what is needed for 12v.
sib Member Since: 18 May 2007 Location: Baaath Posts: 144 ![]() |
Also if you end up towing a normal trailer with 12v electrics you can simply plug in a 24-12v converter to the existing trailer socket. Sib
Bath UK 1952 80 inch 1973 88 inch 2018 Morgan plus 4 narrow body |
