Home > Maintenance & Modifications > Mudflap brackets
Page 2 of 2 <12
jimbob7
My 06,Forestry Commission owned 110,Doesn't need reinforcement.. Pov.spec,ftw. 2006, 110,TD5.
Post #510344 3rd Mar 2016 1:07pm
Flyingfocrs
Scotland 2011 Defender 110 Puma 2.4 USW Santorini Black
MartinK wrote:
Supacat - lovely job, and a few pence rather than £30 Smile
Similar to my own repair
Thanks for sharing Thumbs Up
Same here, i had a piece of 1" wide aluminium flat bar in the shed, cut a length and secured it to the section that had been pulled through and mounted the bracket to it.
Once this snow has cleared i'll have a go at fitting the gwn lewis kit.
Post #510352 3rd Mar 2016 1:16pm
Happyoldgit
That's the idea Supacat. The only comment I have to add is that by using an adhesive you are not only sticking the components together but also forming a gasket between them which salty water should not penetrate. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #510398 3rd Mar 2016 3:10pm
Flyingfocrs
So I made a start on fitting the Gwyn Lewis mud flap brackets and splash guard kit as supplied to me by FCX.
who also win the award for the most packaging tape used on a parcel! Shocked Laughing
I haven't finished fitting them yet as between the sleet and other jobs ongoing it was slow progress.
Plus as i have a XS with chequer plate that causes a bit of fun when fitting the strengthening straps.
I managed to do it on my own but it would have been easier with a second pair of hands at times as the bolt head is in the load bay and the nut up under the tub.
I found the instructions a bit vague at times and the photos are not exactly clear.
if the weather is better next week i'll try to find the time to take some pics and explain the fitting process.
But what i can say is this is what Land Rover should have supplied in the first place not the stupidly flimsy and insecure offering they came up with.
I have all the brackets installed just have to fit the mudlaps to their hangers and put them back on.
In summary though the kit is very good and gets a Thumbs Up from me.
Post #511045 5th Mar 2016 3:57pm
APK
United Kingdom 2015 Defender 110 Puma 2.2 Adventure Corris Grey
Hi, would applying ACF-50 (instead of an adhesive) be as effective against corrosion?
Thanks.
Post #513723 12th Mar 2016 10:26pm
Not really - the ACF 50 is really a regular maintenance item; whereas the point of the sealant is to permanently seal the area from moisture ingress.
Post #513809 13th Mar 2016 9:55am
dunc
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Corris Grey
This and the other thread on this subject appear to be referencing this issue on just the 110. Is it also a problem for the 90? If so front and rear?
Post #513827 13th Mar 2016 10:57am
Not rears on 90 due to the different fixing arrangements between the models - have a look at the front of your 90 and see if the issue is similar?
Post #513832 13th Mar 2016 11:14am
Page 2 of 2 <12
