Home > Maintenance & Modifications > Advice on fitting Nakatanenga Stainless Bolt Kit please :-)
Page 2 of 2 <12
leeds
Best product?
You will never get a consensus of opinion on questions such as what is best .....?
If there is not enough paste just give us a shout.
Nakatanenga have been supplying these kits for years and the kits runs into thousands. If you look at other kits available in the UK, none of them supply any paste and none of them are as comprehensive as the Nakatanenga kits.
Brendan
Post #513725 12th Mar 2016 11:30pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Edzi wrote:
Did you find the supplied sachets enough? Thanks Smile
Plenty...more than enough....I used it liberally as well.
Patrick
Post #513740 13th Mar 2016 1:07am
Edzi
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Alaska White
leeds wrote:
Best product?
Brendan
Cheers Smile
Post #513757 13th Mar 2016 5:01am
Edzi
Patrick
Fab Smile Thanks.
Post #513758 13th Mar 2016 5:01am
dunc
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Corris Grey
How long should one allow to complete the whole job?
Post #513769 13th Mar 2016 8:33am
Justtellme
very simple job....however I did it in stages as I worked on each portion of the vehicle over a few months. Rear crossmember about 20 mins(while trying to fix my rear step), bonnet hinges about 20mins ( while installing a noise killer panel), front grill about 20 mins ( while installing an XS grill)etc......
I would say about 3 hours with the doors and rear door/spare tire carrier accounting for 2 hours of that due to removal of panels.
Not difficult, just be methodical and work your way around.
cheers
Patrick
Post #513777 13th Mar 2016 9:04am
Screbble
If you're going to be playing about with stainless steel fixings on a Landy generally (seems to be something most of us get addicted to), then as others have said, I'd invest in some Tef Gel. Like some other brands that are available, it addresses the issues around galling, seizing and galvanic corrosion in one hit Thumbs Up
Although not necessarily related to this OP, but mindful of the aforementioned addiction, do keep an eye on the tensile strength of any 'critical' or 'structural' fixings you are intending to replace with stainless steel. It's not a problem as there are many, many stainless steel grades available, but do keep an eye on things.
I've had stainless steel products from Brendan before and the paste (and advice) was plentiful Thumbs Up Thumbs Up Thumbs Up
Post #513779 13th Mar 2016 9:12am
Edzi
Post #514266 14th Mar 2016 6:38pm
leeds
As Screbble says there are many grades of stainless steel fittings around
However the most common grade available is A2 which is resistant to corossion, heads of bolts stamped A2
A4 grade is more corrosion resistant being a 'marine' grade of stainless and bolts are stamped A4 on its head.
Strength of mild steel bolts typically available are known as 8.8 which have a minimum yield of 640 MPa and minimum tensile strength of 800 MPa,
Typical stainless bolts are A2-70 have a minimum yield of 450 MPa and minimum tensile of 700 MPa
A4-80 have a minimum yield of 600 MPa and minimum tensile of 800 MPa
HTH
Brendan
Post #514357 14th Mar 2016 10:02pm
Page 2 of 2 <12
