Home > Td5 > Bonnet Mounted Spare
Loz2286
I've always preferred my spare wheel to be mounted on the bonnet. It looks better, the rear door isn't under strain and it's not in the way for cycle carriers etc. On my TD5 CSW it is of course rear door mounted. Paddocks do this kit which they say is not suitable for the TD5. Any idea why?
http://www.paddockspares.com/pm1131-defend...-only.html 1999 Td5 110 CSW
1961 Series 2 88 LPG
Post #513546 12th Mar 2016 3:31pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
TD5 bonnets are the weakest, thinnest bonnets Land Rover ever made. Put a spare wheel carrier on it and it'll fold in half. Some of that, I think, is because the engine sits quite high so they removed much of the reinforcement to clear the engine but it could have been a cost cutting exercise.
The bonnet prop for the TD5 is also too thin to support the weight of a bonnet with spare wheel having replaced the older scissor support with a thin detachable bar. On the military spec vehicles they used a much heftier prop, it's about 1/2 inch diameter and permanently attached to the bonnet instead of being attached to the slam panel and relying on the prop locating into a slot in the bonnet. http://www.yorkshireoffroadclub.net/
Post #513637 12th Mar 2016 7:34pm
Loz2286
Thanks for that info. Shame really as I prefer the look.
Oh well.... 1999 Td5 110 CSW
Post #513645 12th Mar 2016 7:47pm
Fatboy Slim
Wales
Nothing to stop you buying an earlier bonnet with a spare wheel carrier on it.
Post #513652 12th Mar 2016 8:08pm
VeeTee
Netherlands
Or like this...
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #513687 12th Mar 2016 10:02pm
Grenadier
I bet some jobsworth in H&S at the DVLA would pipe up and say VeeTee's front wheel rack wouldn't meet UK road legislation, along the lines of bull bars. Just in case some 2ft child managed to bounce up the slab front of a 4ft high bonnet and land on the wheel. Because that happens ALL the time.... Big Cry Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #513806 13th Mar 2016 10:34am
Fatboy Slim
Wales
To be honest I fail to see the difference between being hit by a 1988 90 or a Td5. I'm sure that someone a while ago had evidence that a defender is actually more aerodynamic with a bonnet mounted spare Laughing so you're doing your bit for the environment really Whistle
Post #513813 13th Mar 2016 11:09am
davew
TBH I'd assumed the bull bar was a necessity as that tyre must mean you can only see about 20% of the road ahead so you use the bull bar like a blind person uses a white stick, to know when you've got too close to something.
I tried putting a 265/75 tyre (without a wheel) on the bonnet as a possible way to carry it on an overland trip. Visibility was so bad that we ruled it out as an option. Take the same tyre and lift it up even higher with a set of bars and that must really limit the view. You'll probably get away with it on tarmac but off road you wouldn't have a clue what was in front or to the LHS of you. http://www.yorkshireoffroadclub.net/
Post #513821 13th Mar 2016 11:37am
shaggydog
I have a 265/75/16 GG At2 on my bonnet and have no viability issues at all.
Only time it is a problem is when trying to park tight to something like a bollard but then I just go as close as I think, get out and look then adjust. Thumbs Up
I'm with the Op on this I think the spare wheel looks great on the bonnet
I would definitely recommend getting a earlier bonnet though. Keep your standard Td5 one and then get an earlier one with the reinforcement and bonnet mounting kit and then get it painted to suit your vehicle.
That way if you don't like it you still have your old bonnet you can just switch back over and then sell your spare wheel one on.
Hope that helps Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #513897 13th Mar 2016 6:45pm
smurf500
England 2005 Defender 90 Td5 HT Belize Green
i did the same with a 110 double cab i used to own.just bought an older bonnet then fitted a earlier type rear door carrier.the only problem i found was it rubbed the sound proofing cover on the td5 engine
Post #515745 18th Mar 2016 3:35pm
kevinf
I've got a tatty 2nd hand bonnet that I put on to my td5 to carry a 2nd spare when I go on big trips, drove thru France, Spain and Morocco last summer carrying a 235/85 16 bfg with out any vision issues or overheating
2 point to watch I use the heavy duty bonnet stay that came with the 2nd hand bonnet, there's a suitable hole in the bonnet slam panel to receive it and I manage to break the top bit off the alarm bonnet switch which still worked fine with the 2nd hand bonnet, but isn't long enough with the original td5 bonnet, so would be an idea to remove it whilst your running with a different bonnet!
hope this helps
Post #517375 24th Mar 2016 1:44pm
wimvanzomeren
Netherlands 2011 Defender 130 Puma 2.4 HCPU Barolo Black
VeeTee wrote:
Or like this...
Hi Vincent; waar kan ik zo'n reservewiel dragen kopen?
Post #879912 21st Jan 2021 1:08pm
discomog
You definitely need 3 weetabix for your breakfast if you want to lift the bonnet up with a spare wheel on. Working on the engine has its dangers if you accidentally knock the bonnet stay. I also find it very distracting when driving, particularly off road.
I agree it looks the part but looks aren't everything. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #879918 21st Jan 2021 1:54pm
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
I wouldn't be without mine. If you get the correct solid bonnet stay, it locks into the radiator slam panel so can't be knocked out. The clean and jerk method is the best way to open it.
Visibility isn't an issue because a Defender has straight body lines, so you can visualise where the far corner is quite easily. LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #880007 21st Jan 2021 8:44pm
roel
I have a 1984 bonnet on my Td5.
The engine sound proofing just touches sometimes the internals off the bonnet.
The scissor type support doesn't fit as it touched something under the bonnet. I don't remember what.
So I use the td5 stick, however there is not a real good hole to stick it in so if I do some work I tie it to my rollbar or take it off completely.
On my first 90 I had a bonnet mounted spare. I liked the looks and yes you have some reduced sight just in front off the Land Rover but that was only a problem off-road. I had a 7.50 x 16 not a 265 that makes a lot off difference too.
The bonnet was heavy to open so on my td5 I didn't bother with it. Roel
2003 90 Td5 (2009-now)
Post #881289 27th Jan 2021 1:11pm
