Home > Puma (Tdci) > Oncoming lights reflections
neil5886
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Indus Silver
I have noticed while driving my 110 XS in the dark that I get a bad reflection in my rear mirror of the oncoming car, i'm guessing its due to the angle of the back window, where I live there is no street lights at all which seems to make this worse.
So I am thinking of a way to reduce this effect, would tinting the rear window help at all, as anyone had the same issue and found a solution.
Post #513112 11th Mar 2016 10:14am
RRUK
This has been discussed at length many times before.
Tinting makes no difference, there is absolutely nothing you can do about it. It is indeed due to the angle of the rear glass acting as a mirror to oncoming lights which are then seen in your rear view mirror.
Just something you have to get used to, or, remove the rear view mirror as some have done. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #513114 11th Mar 2016 10:16am
neil5886
Okay thanks for the reply, my old 110 didn't have a rear window so this reflection issue is new to me.
I am useless using the forum search I can never find anything.
Post #513121 11th Mar 2016 10:48am
Cupboard
Is there any requirement to have the rear view mirror? Mine's pretty pointless and I don't have a rear wiper either.
Post #513123 11th Mar 2016 10:50am
Yes.
C&U (as far as I recall) requires that a vehicle is fitted with a minimum of 2 rear view mirrors, one of which must be external and on the offside. the other can be either internal or external and on the nearside, but must be internal unless for some reason an internal won't give a view to the rear.
So stricly speaking if you have a rear window, you must have an internal rear view mirror.
This is a change from a few years ago when there was no restriction on the second mirror and either internal or external was acceptable without qualification.
I suggest you're unlikely to be stopped, and I don't think it is an MOT failure as long as you have two mirrors.
Post #513126 11th Mar 2016 10:53am
RRUK
If you want to see what its like to not have a rear view mirror you can easily remove the original quickly, and replace in a matter of seconds.
Grab the arm firmly and turn the entire unit clockwise or anti clockwise, it will then release.
You can look at the spring mechanism after to easily see how it goes back on.
This is what the base plate looks like.
 2016 D4 HSE
Post #513128 11th Mar 2016 11:01am
Happyoldgit
It's been a quirk of the vehicles for the past few decades, you quickly adapt. I wouldn't even bother removing the mirror, just ignore it and use the exterior ones instead. Steve.
http://forums.lr4x4.com
Post #513136 11th Mar 2016 11:38am
Cupboard
It would be quite a handy place for a screen, either phone or rear view camera.
I'm getting increasingly motivated to fit a reversing camera because I've got issues with a particular car park.
Post #513139 11th Mar 2016 11:45am
Mud do a fab Bracket my Sat Nav is mounted there (At times)
Post #513155 11th Mar 2016 12:34pm
jimbob7
Imo,remove internal mirror,then save thousands on rear wiper blades/motor repairs etc.IF any police/vosa pulled you I doubt very much they would mention a missing interior mirror,at the most it would be a recommendation.
mot;
http://www.motuk.co.uk/manual_810.htm
cu regs;
http://www.transportsfriend.org/road/mirrors.html
Also rear wiper is not a testable item,so doesn't have to work. Pov.spec,ftw. 2006, 110,TD5.
Post #513236 11th Mar 2016 4:51pm
Christian1402
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Indus Silver
My hard top didn't have a rear view mirror, yet the bulkhead was a standard one, not full height.
I just presumed they came from the factory like this. Either way it didn't both me, the rear view mirror of my discovery is useless due to the 3.5" lift and huge spare tyre. I'll probably remove the one from the xs when I get around to it, as the reflecting light does annoy me
Post #513272 11th Mar 2016 6:40pm
Cupboard
I have a 110 HT with no lift and the smallest tyres you get on a Defender. The rear view mirror is still completely useless for manoeuvring.
Post #513382 11th Mar 2016 10:23pm
Riccarton
Scotland 2012 Defender 90 Puma 2.2 HT Zambezi Silver
blackwolf wrote:
Yes.
Any idea when this changed? It used to be "a) an external mirror on the offside and b) an external mirror on the nearside OR an internal mirror." Thereafter, any additional mirrors were not testable items.
I often wonder why they can't just leave things alone that don't need fixing and yet leave alone things that do need fixing !!
Post #513461 12th Mar 2016 10:17am
Almost certainly Europe has something to do with it. It is fairly recent.
Post #513662 12th Mar 2016 8:31pm
Ryderoo
England 2015 Defender 90 Puma 2.2 HT Santorini Black
I am in agreement with happy/ miserable just man up and live with it. Just another Defender quirk, I have got used to it. Cheers Simon
I can explain it to you, but I can't understand it for you
1990 110 TD5 county, my first Land Rover - gone
2012 Discovery 4 XS SDV6 - gone
2014 Discovery 4 XS SDV6 - gone
2015 Evoque SD4 dynamic - Wife’s - gone
2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone
2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24
2021 Defender S D250 Santorini Black 110 HT - gone March 24
2023 Evoque P300e SE wife’s current vehicle
Post #513754 13th Mar 2016 3:02am
