Home > Tdi > 300TDI FIP Adjustment - nylon washer?
LRmud
Scotland 1989 Defender 90 300 Tdi HT Baltic Blue
Just tuning up the Fuel Injection Pump on my engine and have a query.....
I've read some reports/tuning guides which mention removing the nylon washer which sits over the so called Boost Pin. Other guides say to trim it down "a bit". Other guides do not mention anything other than "don't lose it".
Can someone clear up the nylon washer anomaly please?
The washer appears to set the maximum fuel position of the Boost Pin - like an "end stop" for max turbo boost.
Choices appear to be;
Should I refit as normal?
Should I trim it down a specific amount?
Should I throw it away?
As always, comments and suggestions very much appreciated. --------------------------------------------------------------------------------------------------
1989 Defender 90
Toyota Aygo & Honda FR-V
Post #512917 10th Mar 2016 8:03pm
jst
try it with it out compared to with it in against performance EGT etc
if too much black under full boost or too high an EGT then refit it.
my tgvs still have them in there, you can tweak them to run fine with them fitted. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #512959 10th Mar 2016 9:19pm
