![]() | Home > Technical > ECU Tuning TD5 |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
Hi Philip,
I'm no expert on tuning but have tried both plug in and ecu tunes, by far the best is the ecu tune. Ive got a 'tune-my-diesel' chip fitted to my wife's Shogun, it's very basic, it does make a difference to the fuel economy and add a small amount of power, if turned up too high it tends to smoke more, and can purge on tick over, it's ok, but only ok. A plug in device 'fools' the ecu and squirts extra fuel in when you put your foot down. Some are better than others, some cheap ones simply contain a couple of resisters. The thing about a good ecu tune is that YOU decide how much power, where you'd like the torque curve to be, how you'd like the drivability to improve etc, then a good tuner should be able to input that info. Every engine is slightly different, some have low or high miles, some run rich, some lean, different climates, state of tune (EGR removed, filters etc) all of which should be taken into consideration. I went to Alive (sponsor on here) and had excellent results, my fuel economy is better, more power and low down torque, much nicer to drive. Then about 18 months later I visited again for a check-up, partly because I'd changed the ratios in the transfer box, Gary checked everything over, recommend a new MAF sensor, fitted one, then tweeked the tune slightly. Again - an improvement. There's several sponsors on here that will do a postal service, much better than the plug in option. Lambley |
dave18 Member Since: 11 Jul 2015 Location: Gorleston, Great Yarmouth Posts: 497 ![]() ![]() ![]() |
Best advice would be call Gary at Alive Tuning, there is less than a handfull of people who properly tune the Td5 and he is the top dog along with some one else but cant remember their name, Generic chips are crap. Gary will only tune once he is happy the engine is sound. so if the MAF or injector loom is faulty he will tell you rather than botch it.
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 277 ![]() ![]() ![]() |
Hi Philip
Some plug in modules are quite crude and just tweak the fuel - more fuel = more power. I agree with the others - you ideally need to tune the ECU. My TD5 was tuned by Pete Bell at BAS (probably the other guy Dave18 was referring to). Prior to that, it had an Austrian plug-in module fitted (SteinBauer) - the tune by Pete is far superior Tony |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2268 ![]() ![]() ![]() |
Lambley, which stage did you go for if you don't mind me asking? What sort of information do you provide to obtain the 'best fit?' Is it just a case of explaining your typical driving style/conditions, or do you actually 'play about' with tuning options before finalising? Apologies for sounding a bit thick! ![]() |
I had a kind of in-between stage 1-2, I've done some mods myself, EGR removed, bigger intercooler, silicon hoses etc, the usual stuff, then I went to see Gary at Alive, explained I didn't drive fast, just wanted more torque, better mid range driveability, not out and out bhp, we aimed for around 150 / 160 bhp, I didn't want to put the engine under stress, just make it nicer to drive. It's the torque that matters, not the bhp.
Gary did his stuff, checked everything over, then we went for a test drive, then back to base for a chat. Then another slight tweek, another test drive to make sure I was happy, which I was. On the 2nd visit18 months later, I asked Gary if it was possible to lose the initial surge of low down power on pulling away, seems a strange thing to ask for maybe, but I don't boot it from the lights, he did just that, it lost the jerkiness in first gear, made it smoother. During that visit Gary recommended a new MAF sensor which he fitted too. He only charged me for a 'tweek' as I was there less than an hour. It's a case of explaining what you want out of a tune, some tuners will say they can get 200bhp easy! Don't listen to them, just go to somebody who knows what they're doing and tell them what you'd like to improve, I get 3 mpg better fuel economy, an extra dollop of grunt, all of which make it much nicer to drive. |
Thanks Lambley, very helpful.
I intend to visit Gary this year (pocket money allowing) and go for a stage 1. I don't 'boot' it but it'd be good to talk him through how I drive and what I'd like - obviously with his experience and input guiding the outcome. Thanks for your pointers ![]() |
Philslandy Member Since: 10 Sep 2013 Location: Eifel Posts: 156 ![]() ![]() ![]() |
Thanks for your postings!
I have quite the same expectations like you Lambley ![]() I have also done all the modifications that Lambley did... Problem for me would be, that These specialists are all in Britain - i would have to combine it with a nice trip ![]() Would somebody have a link for me? One Thing i want to Change for better is the junction between snorkel and air filter box - i feel there is a need to breed much better |
Here's the link, Gary does a postal service, if your mods are similar to mine you could ask him to put my map onto your ecu, just an idea.....
I took my mates Defender ecu with me on my 2nd visit and described everything he wanted, more torque and low down pull but not jerky as he often pulls horse boxes, he was equally as pleased with the results. http://www.alivetuning.com/ |
I agree that a GOOD ecu tune is better then any plug in boxes, however you can also get Bad ecu tunes.
There are good tuning boxes and Matzker is one off them. The wrong ones changes data from sensors and let the ecu think more fuel needs to be pumped in. The better ones like Maztker and PSI just ad some fuel by keeping the injectors open a little longer.' Why is this better then changing data from sensors? because all safe guards that standard are build in the ecu keep working. A ECU tune does more or less the same It also injects more fuel with the same engine parameters. The nice thing with a box is you can switch it off if you want it. I have a PSI powerbox. I made a 3 way switch. Off- ON - On only at full throttle. And the last one works great as I have it at MR Zulu setting and it smokes a little. I could go a setting back, but why if I only use it at full throttle. ![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
sandu Member Since: 30 Jan 2015 Location: Chisinau Posts: 11 ![]() ![]() ![]() |
if you were to choose the TUNER
which one you would go with and why? 1. Alive 2. BAS 3. Matzker 4. IRB 5. other LR DEF 110 TD5, 2000. LR DISCO-2 TD5, 2001. ARB Difflocks, front + rear. Ashcroft CV Joints + Halfshafts.. Transferbox 1.410 ratio. Warn M12000 + Warn 9.5xp Maxxis Creepy Crawler 255/85R16 |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
JE engineering
they don't offer to change the turbocharger though
I wonder how much is decreased the engine reliability and lifetime? LR DEF 110 TD5, 2000. LR DISCO-2 TD5, 2001. ARB Difflocks, front + rear. Ashcroft CV Joints + Halfshafts.. Transferbox 1.410 ratio. Warn M12000 + Warn 9.5xp Maxxis Creepy Crawler 255/85R16 |
Well my last vehicle is on over 300,000 miles most of it towing 3.5t so I'd say fairly reliable
![]() Remapped by JE at 48,000m serck intercooler de-cat and EGR removed. |
The tuning does do bad things to your engine, it the driving style that hurts. ![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
