![]() | Home > Maintenance & Modifications > Wiring up spots |
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 ![]() ![]() ![]() |
Right,
being a bit of a heavy handed bafoon when it comes round to the finer points of land rover ownership i am slightly dubious about wiring said units into my vehicles intricate wiring harness. Oh and the fact that i will probably melt something ! set it on fire spike the ECU are also niggliing me a bit. so, the question is do i do it ![]() Or is this something that should be done by somebody who knows about vehicle wiring ![]() Is it spliced into the vehicles FULL beam or can it be dash mounted on a switch to come on regardless of the FULL beam being on or not. I did see a while back some PIAA Spots that are to replace the WARN units on the 09 G4 vehicles. These had a very trick switch that has a number 2 on that fits in the correct space on the dash. Anyway, as always any info will be much apreciated. DEFENDER XS CSW 08 TONGA GREEN |
mike
you are the font of all knowledge ! the spots look pretty dismal from the dealer but the wiring for them looks pretty substantial ! That said and following on from our conversation last night, how much can you purchase the Loom for ![]() And again following on from conversation EXPENSIVE as ever ! DEFENDER XS CSW 08 TONGA GREEN |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5111 ![]() ![]() ![]() |
I wouldnt go that far...
I would have to go to "That dealer"! Ill ask next time im there Its bigger items the savings are great - except a car which is 12% on top of other offers Here you are: YUG000540LNF � Front Fog switch, Check price check for Aux 2 Wiring loom �98.64 Have a look at GTR the public side for the fitting guide i have it in pdf if you want me to email it, just pm me Mike |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
Yes that's the part (YUG000540LNF) I made up a harness and the switch cost me about ₤8 including postage to Australia. Over here it's not even a listed part
![]() Pin outs are: 1 feed 2 illumination (take from pin 2 on another switch - lights up with other dash lights then) 4 ground 5 line out to lights (relay) It takes a black connector, which I couldn't get and which is part of the wiring harness that LR supply. 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
So does that part come with the 2 and light symbol in it... as the pictures i cant tell! Mike
The pins on the switch are all numbered, bit hard to read as they are down inside the switch (against the respective pins) from memory its 1-5 right to left, but double check.
Yes that part does have the 2 and light symbol. Found the other thread on the forum: http://www.defender2.net/forum/topic552.html?highlight=switch Dave's 101 posted up some links to pic's of the switch in this thread. 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
I wired a bank of those switches on my disco (they are the same as RR classic and d2
![]() thanks for the confirmation of switch facia type. Mike |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 510 ![]() ![]() ![]() |
I've posted some info on wiring YUG000540LNF in the Switch Fascia thread -
http://www.defender2.net/forum/topic552-15.html Paul. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
We had the LR driving lamps fitted before collection at good price, the '2' switch is in the kit. 2.4 90 XS
ive also i created a post a few weeks ago about fitting the switch http://www.defender2.net/forum/topic795.html Mike
