Home > Technical > Nakatanenga LED Side Repeaters - Drivers side Flashing Fast
R500DEF
United Kingdom 2008 Defender 90 Puma 2.4 CSW Santorini Black
Hello all, i have recently purchased some Nakatanenga LED clear side repeaters. I have fitted them and the drivers side indicators front , side and rear operate much faster than normal speed.
I have swapped the unit and the fault does NOT transfer to the passenger side.
The repeaters have a built in flasher relay
Some info from the manufacturer:
''The indicators work with both the original flasher relay from the Defender and with the adjustable flasher relay in the Nakatanenga LED Signal Lights set - so no need to buy a flasher relay or exchange"
Can anyone advise?
Thanks in advance Thumbs Up
Post #512562 9th Mar 2016 8:01pm
leeds
If the fault stays on the drivers side when you swop the indicators from one side to the other then it is unlikely to be a fault in the LED repeaters.
The repeaters do not have a flasher unit in them.
They will work with the original flasher unit IF you have the original filament bulbs in. The change in resistance by changing just the side repeaters is not enough to upset the original flasher unit.
If you have changed the original indicators to LED then you would need to change the flasher unit, again the side repeaters should not effect things if you have changed the relay.
It would seem that there is an issue with your vehicle wiring, but what?
I have asked Peter to have a look at this thread.
What are your front and rear indicators? LED or original filament?
If LED I would suggest you swop them over as well and see if the problem stays on drivers side or swops over as well.
Sorry I can not be more helpful at this moment in time.
Brendan
Post #512603 9th Mar 2016 9:19pm
LED's tend to be more sensitive to voltage fluctuation and earthing issues.
I'd check voltage on both sides and earth continuity, proceed from there then.
Post #512604 9th Mar 2016 9:23pm
R500DEF
Thanks for the reply Brendan. All my other lights are filiment. These are all working perfectly even the filiment side repeaters.
The fault only occurs when fitting the LED repeaters and the fault occurs to the drivers side. Confused
Post #512607 9th Mar 2016 9:26pm
R500DEF
I will check that out at the weekend Steve - ill dig out the multimeter Thumbs Up
Post #512612 9th Mar 2016 9:34pm
Good luck, hopefully it will be simple. Thumbs Up
Post #512616 9th Mar 2016 9:42pm
leeds
Just to be clear ALL three indicators on the drivers side flash fast when you put a LED side repeater in?
If that is the case I would wonder if you need to change the flasher relay?
The only thing which confuses me is why the nearside does not do the same.
Slightly higher resistance through the earth contacts on the near side maybe?
Brendan
Post #512625 9th Mar 2016 10:05pm
R500DEF
Correct Brendan, we checked and all 3 of the drivers side indicators flash at the faster speed when the LED repeater is fitted.
Post #512629 9th Mar 2016 10:10pm
nakatanenga
Germany
hmmhm, that's crazy!
The LED side repeaters have about the same resistance as the filament ones. This usually provides enough resistance that the standard flasher relay stays in the "everything upright mode"
As your problem only occures on one side i tend to say that your relay is kind of faulty. Do you have the chance to change it to a different one? Either a normal one from a different Puma or an adjustable LED one.
Peter WANTED:
SII or SIII in max 1.5k
Post #512634 9th Mar 2016 10:16pm
R500DEF
Hi Peter, i dont have a replacement relay to hand. I will have to purchase a new relay to possibly fix the issue.
Would you reccomend a new replacement relay or a wipsc 12v adjustable flasher relay?
Thanks
Post #512645 9th Mar 2016 10:37pm
leeds
R500,
If you want to pm me your address I think we have some adjustable ones on our shelves which I could stick in the post and you can try it out this weekend to see if it solves your problem. If it doesn't send it back, if it does we will sort something out.
Brendan
Post #512652 9th Mar 2016 11:04pm
R500DEF
Brilliant, i appreciate that Brendan. Will send you a PM over now.
Thanks for the help people. Hopefully get it sorted
Post #512654 9th Mar 2016 11:07pm
R500DEF
Thanks for sending the relay over Brendan Thumbs Up . Fitted the relay and the drivers LED repeater flashes as normal but the passenger LED does not flash at all now Surprised .
I have reverted back to the standard relay and filament repeaters and this is working fine. Soo confused.. Laughing
Post #513895 13th Mar 2016 6:40pm
leeds
Something is very odd here.
Is this a new vehicle? Or owned by you from new?
Daft as it might sound do you have towing electrics? If so is that socket all clean and sound or full of mud and corroded to hell?
Brendan
Post #513912 13th Mar 2016 7:13pm
R500DEF
I know its strange. The vehicle is a 2008. Yes i have towing electrics, i checked the socket last week and sprayed Wd40 in to clean it up as it looked to have sand mud around etc. Maybe a thorough clean might be needed.
Its strange as the standard filament lights work as they should.
Post #513915 13th Mar 2016 7:19pm
