![]() | Home > Technical > TD5 Clutch too high. |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge hight adjustment you use two nuts as shown pic one ( 2 ) ![]() Click image to enlarge ![]() Click image to enlarge pic from my 06 td5 90 Last edited by dorsetsmith on 7th Mar 2016 3:18pm. Edited 1 time in total |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 688 ![]() ![]() |
Thanks for the photos, sadly on ours there's not sufficient thread available to get the pedal height to meet that spec. So am stuck. It is adjusted as far as the nuts will permit without running off the end of the shaft. The lock nut is barely in contact with the nylon part of the locking feature and the shaft. Therefore I'm thinking the shaft should be settling further in by default.
which end of the thread are you working with ( cylinder end )
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
If your pedals too high you want to adjust it the other way from the sounds of things if the locknut is nearly off the end of the thread
I'm not even sure there's enough thread there to get all the nuts on and still have any adjustability anyway to be honest.
Tell you what I'll take some photos later and post them up. Thanks for the helps guys really appreciate it. Will see if someone can take a pic for me. Not with it at the minute. Will show you the problem. ![]() |
Good man. You might end up putting a shim in between the slave cylinder and the bellhousing. Stick some pics up and we'll have a look
Ok here goes then.
A photo or two. All fairly self explanatory. Anyone see anything unusual or strange? The clutch is way too high..... ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
the cylinder push rod look ok looks no different my one up the page
if you slacken the two nut and re adjust it slightly you will get the pedal hight down slightly Last edited by dorsetsmith on 8th Mar 2016 10:22pm. Edited 1 time in total |
That's what I was thinking.
See what I mean about the adjustment? No way there's enough adjustment left to get the pedal down to where it should be.... Unless I'm missing something. |
you can adjust it and it will be ok if you look at my one up the page i have no thread showing and the pedal is find. if you change enough master cylinders you get to right every time
![]() Last edited by dorsetsmith on 8th Mar 2016 10:30pm. Edited 1 time in total |
I'll have a go and see what it gets me to. Worth a try I guess.
![]() Will take a shot when it's done and see! I guess the lever ratio is significant so even 3 to 4mm which is all I reckon I've got might have a big effect at the other end of the pedal. |
that right
