Home > Td5 > Defender won't start strange dash lights
L90DNY
United Kingdom 2006 Defender 90 Td5 HT Corris Grey
Evening folks, I am re-building a td5 currently. Recently put in a lower milage td5 engine, all good swapped the injectors over from old engine, everything was running fine. Left it in the workshop ready to waxoxyl it the next day, cracked on and thought about halfway through the day should probably start it... and got nothing. Didn't even turn over, like there was a flat battery, put a fresh battery in just incase it had drained over night or something. Same thing.
However, I get lights on the dash that stay on, these are the indicators, fog lights and side light lights ?
Any ideas can't find anything about those warning dash lights anywhere online ?
Post #511826 7th Mar 2016 11:18pm
JWL
That's a new one on me, I would be leaning to double checking the battery condition and instalation, then double checking over what you had done to prep it in readiness to waxoyling.
Post #511840 7th Mar 2016 11:36pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Check grounding - between battery, chasis and engine. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #511880 8th Mar 2016 8:18am
L90DNY
I'd had taken the wings off, as new ones are going on. As I understand it the alarm is in one of the wings, so I plugged them back in and tried again with the same result. I cleaned off the earth to the chassis from the battery, and tried two separate batteries, checked them both with the volt meter putting out 13 volts, so no issues there.
Very strange, might have to get a computer plugged into it. The only thing I didn't try on the off chance might work was unplugging and re plugging the ECU in. Must some sort of weird electrical gremlin, 1 step forward 2 steps back !
Post #511907 8th Mar 2016 10:02am
Martin
Site Admin
Does the ignition turn on as normal - i.e. you get glow plug light on (then off), charge warning lamp (battery symbol), dash gauges move... or not?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #511914 8th Mar 2016 10:25am
L90DNY
Yes, lights all come on glow plug comes on and goes off. Milage shows up etc, then they all the lights go off but the indicators, fog lamps and side lights stay on.
Post #511919 8th Mar 2016 10:36am
JWL
It's beginning to sound like a problem around the dashboard/switch housing by steering wheel. Perhaps the multi-plug behind the dash clocks where it takes feeds from the indicator, lights and fog light switches.
Post #512010 8th Mar 2016 2:17pm
miker
Are the actual lamps on as well as the indicators? My money would be on grounding. Block to chassis strap, any other grounds in the engine bay.
Post #512014 8th Mar 2016 2:19pm
L90DNY
It is just the lights on the dash, not the actual lights that are on. I thought it was some kind of warning light sequence, but haven't found anything about it yet. I will have to check all of the grounding points next
Post #512065 8th Mar 2016 3:53pm
