![]() | Home > Technical > Swivel ball pin |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
Blimey, the bottom one is the Td5/transit type. They all interchange pretty much anyway so long as you change the bearings etc all together so I wouldn't panic too much.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6691 ![]() ![]() ![]() |
Your lower picture looks like the Td5 arrangement - TAR100040 (non ABS axles) or TAR100050 (ABS axles).
The ABS version appears to have a hole down the middle. I assume you have been sold a Railko type pin and bush based on your reg/chassis number. ![]() ![]() |
They've sent him packing with the TDI type from the looks of it. I'm shocked they didn't recognise the one you want, it's pretty much the most common type out there now.
True it is a bearing type pin in the pic but they are library pics
Mikey90blue Member Since: 06 Mar 2016 Location: Beverley Posts: 2 ![]() ![]() |
Thanks for the replys guys they sent me a pin and bush the first time, which didn't fit then the second one time they sent the wrong bearing so the third Time I went with the bearing and pin and they sent me away with the top picture which on initial inspection appears to fit will it be okay to use may just need some more shims or less ?
It will fit as long as you have the correct corresponding bearing for it. May need more shims, may need less. Just set the swivel up and it'll be happy days
