Home > Puma (Tdci) > 'Unique engine tune' for varying fuel quality....?
Caterham
Firstly, Hi.
this is my first post, but a question thats been on my mind for a long time.
(only just been introduced to the website - thanks Shropshirelad) and what a great website.
anyhow back to the big question, if anyone has noticed the comment 'Unique engine tune' for varying fuel quality in the Land Rover literature do they know what it actually means?
is it an ECU mod, or other things?
Post #4540 6th Nov 2008 11:07pm
AndrewS
Hi and welcome. Must admit never seen that comment. Where did you spot it Question
Post #4541 7th Nov 2008 2:26am
Eduardo
Hi Caterhan
First of all welcome aboard.
As far as I know the Duratorq motor has been modified to use a wide range of diesel quality (sulphur content).
That should involve the ECU programming but also should consider modifications in the inyection system and other components to reduce the SO2 emmission levels (part of the current problems I believe).
AndrewS: The commnents comming from here
http://www.landrover.com.au/au/en/Vehicles...ission.htm
Something similar appears in the LR UK webpage
Regards Eduardo
Post #4542 7th Nov 2008 5:24am
Caterham
I have spoken to Land Rover and the unique engine tune they mention in the 2007 brochure I understand is intended for exports to parts of the world where varying fuel qualities might be encountered.
The reason for not offering it here is due to not complying with emissions.
It would seem they won't tell you want it involves, or offer it as an after market modification either? Evil or Very Mad
Me thinks Biodiesel would work nicely on it. Very Happy
Post #4545 7th Nov 2008 9:26am
Shropshire Lad
Caterham
I've already told you that my dealer said the engine had been developed to run on bio..... Wink LR 90 XS GONE! Hurrah!
Post #4546 7th Nov 2008 10:24am
Caterham
Shrop.lad.
I know but Land Rover won't tell you that. A 'mate' of mine is running circa 30% bio (home made I believe) and up till has seen no difference.
I once drive a Def. 2007 with circa 70% bio and I'm sure it was pinking (but wouldn't put money on it).
Does anyone on here know of anyone who's running on Bio diesel .......(shut up Shropshirelad) Question
Post #4547 7th Nov 2008 10:37am
mse
Ive asked this (at a selection of levels)
Apparently it does different maps (such as low has a different map) etc etc
Ive also been told (not by the designers) that it wont run on bio - the manual actually says this aswell Mike
Post #4550 7th Nov 2008 6:15pm
Laurie
I'm told by a reliable source that the only reason that LR say you shouldn't run on bio-fuels is that the factory haven't done sufficient test mileage to state catagorically that they are OK.
Post #4553 7th Nov 2008 6:22pm
Caterham
I've been told that one of the dealerships is running a transit tdci on bio as a test vehicle and like I said I know someone running circa 30% bio (althought low mileage) with no problems to date.
off at a slight tangent the same mate has a 1.6 common rail Citreon Picasso (same engine as the focus 1.6 tdci) and has run 100% for the last 6-7ooo miles with no problems ! ?
Post #4595 10th Nov 2008 11:35am
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
The export markets get what is called an "EU2" tune (as opposed to the "EU4" tune sold in the UK/Europe) it is supposed to be more tolerant of the brown sludge that is sold in far flung parts of the world under the name "diesel". Time will tell...!
I have no idea what the actual differences are on the engine though.
Post #5067 27th Nov 2008 2:58pm
bell-auto-services
EU2 runs a part cat instead of a full cat, and some mapping differences.
The rest of the engine is the same from what ive seen of it.
Regards Pete
Post #5078 27th Nov 2008 9:29pm
Caterham
sold the cat bit (I'm not bothered about that - I'd like to drop it all together).
the mapping bit does interest me. could this make the difference between fuel igniting prematurely or not. If it were a petrol engine I guess it would be called pinking and you'd advance / retard the timing, but on a diesel?
I've been told (and this is purely out of interest Whistle ) that running the puma defender engine on biodiesel makes it prematurely combust and hence pink Question
can this be so?
Post #5113 29th Nov 2008 8:46am
bell-auto-services
I dont know anyone who has ran a puma on boi.
Dropping the car al together is no problem, which is why i have the decats made after my prototype was a sucsess.
Regards Pete
Post #5116 29th Nov 2008 10:40am
Caterham
I do.... Whistle
just hope it doesn't end in Crying or Very sad
Post #5124 29th Nov 2008 12:43pm
Caterham
someone must know for sure if the eu2 is simply a case of cat removal and mapping?
are the piezzo injectors too fragile for rough fuel / do they replace them too?
Post #5334 8th Dec 2008 10:52am
