![]() | Home > Technical > Puma Heater |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
I think there is a known problem with the heater that makes it do that, im sure somebody whos had it fixed will be alone soon!
Pete. |
shingwell Member Since: 13 Mar 2009 Location: herefordshire Posts: 45 ![]() ![]() |
There is a fix somewhere on here for heater output difference - do a search - which involves removing the heater matrix and covering part of it in aluminium foil.
My dealer measured a difference of 2C between the passenger and drivers side on mine, and then measured several other Pumas and found them all to exhibit the same problem I haven't actually tried the fix yet myself (can't be arsed to remove the heater matrix atm) but it causes problems for me (driver) and mrs (passenger) as she notices the cold quicker then me anyway - if the problem was the other way round it would be a definite positive feature! |
Gabriel Boff Member Since: 19 Apr 2009 Location: Rio Grande do Sul Posts: 95 ![]() ![]() ![]() |
Yes, it's a Defender foible!
But have an instruction named: "Heater Core Combing Process", I have it buto don't know how to post it. Mine do the same, but the drivers side is hotter (because its left hand), I didn't do this "process" and don't know if it works 100%. It's another Land Rover thing!!! cheers |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
I have been wondering if there is anyway of slowing the fan down a bit more even on no 1it seems fast what controls the fan speed is it a relay.
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 ![]() ![]() |
if you open your window a tiny bit and put it on 0 ,: a venturi effect will suck air out of your truck , and in return sucks air into your heater ... or -solder an extra resistor and switch between it - you could even do with a potentiometer - so you will get total control Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17913 ![]() ![]() ![]() |
Mine does exactly the same thing.
The service bulletin is SSM39653, see:- http://www.defender2.co.uk/gallery/albums/...er_fix.pdf However this is stated to be applicable to LHD vehicles only, and mine is a 2007 RHD (on mine the passenger (ie left) side air is much hotter than the drivers (ie right) side). Anyone know if SSM39653 is also applicable to RHD vehicles, or if there is an equivalent modification? |
