Home > Technical > Puma front door fitting issue
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Has anyone encountered this before? I have stripped and repainted a set of 2008 front doors, all upper parts (spacers, gutters and waist seals are brand new Genuine).
When I went to fit the exterior waist seal, it appears that the door has a "bow" in the middle, so it doesn't contact the seal. The old seal seemed to have no issues.
Has anyone seen this before? wondering if the skin could have come un-bonded from the frame at the top???? Next step is to go back and tear it down and try to figure it out.... but I figure I would see if anyone has experienced this before.
 it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #510803 4th Mar 2016 9:18pm
That is quite badly bowed.
Where did you buy them from may I ask?
They shouldn't bow on their own accord without force, or at least I've never seen or heard of it.
Post #510850 4th Mar 2016 11:49pm
CDN38
Seems to be close to 6mm. The other door is about a 3mm bow, but the seal fits fine.
Bought them about a year and a half ago from a breaker in Dorset. it's a Landrover thing...
Post #510871 5th Mar 2016 12:59am
Do you think there was damage due to force of impact? That may have caused it if it was accident damaged.
Post #510875 5th Mar 2016 1:24am
mk1collector
Is it just the skin or the frame too that is bowed? I think my td5 doors have a small rivet in the middle of the top edge of the skin holding it to the frame under the waist seal. Ray
My build thread
Post #510878 5th Mar 2016 2:56am
CDN38
I'm going to take off the window regulator and pop the glass out tonight and have a look. There is a bit of play (I can squeeze the skin and frame together and get movement of the skin) couple mm at least.
Once it's apart, I'll have a better idea what's going on. it's a Landrover thing...
Post #510879 5th Mar 2016 3:29am
If you can move it back together then it should be okay to sort out.
Providing as above the door frame it's self fits okay.
Good luck. Thumbs Up
Post #510957 5th Mar 2016 11:36am
CDN38
Stripped down the door, and definitely there's a crown in the middle. The frame is straight, didn't look like any previous collision damage.... but the blob of bonding adhesive in the middle was so thick, it looked like it may have been creating the issue...oh well, onto a solution. (build tolerance?) Laughing
Slipped a hacksaw blade between the skin and frame to remove and release the existing bonding agent. Did a dry run with 2 clamps and a couple blocks of wood, and it looks like with a little pressure it comes down nice and even.
Used a 3M 2 part epoxy bonding agent ( http://3mcollision.com/3m-automix-universa...black.html ) borrowed from the bodyshop down the alley. Thumbs Up
They use this stuff for bonding steel and aluminum in collision repair. Tested it out on 2 pieces of aluminum. After 30 minutes, they were permanently attached, wow, this stuff is AMAZING! All fixed and ready to go!!
Post #511690 7th Mar 2016 6:38pm
Glad it's worked out for you in the end. Thumbs Up
Post #511704 7th Mar 2016 7:12pm
