![]() | Home > Series Land Rovers > Inane Friday night question! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17839 ![]() ![]() ![]() |
Which bits?
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
The axles should fit
Roscopcoltrane Member Since: 16 Aug 2015 Location: Ayrshire Posts: 19 ![]() ![]() |
The engine and drive train was my priority? Is it feasable ?
You want to take the V8 out and return it to 2286cc?
That should work, engine and drive line are essentially the same on a lightweight. |
With. New mounts for whichever engine and box you're going to use yeah
Apologies guys not making myself clear, If I buy lightweight can I bolt on my series 3 panels?
Trebro Member Since: 28 Jan 2016 Location: Hampshire Posts: 244 ![]() ![]() ![]() |
Why buy a lightweight? if you want compatibility to your series three bits buy a series 3 and save yourself some cash!
The bulkhead differs so wings and door bottoms won't work, the rear tub is one piece, I guess you can swap the door tops and windscreen though...... |
