Home > Maintenance & Modifications > Dead 06 plate TD5 90
TC
A mate has just been trailered (literally) to his local dealer due to an apparent fueling / fuel starvation problem. Symptoms are sharp drop off in power, chug to a stop, leave for five or so minutes and then it will restart again. RAC man bi-passed the filter (which wasn't pretty by all accounts) and the problem persisted; he had a new fuel pump two months ago......
Has anyone got any idea's?
Post #51054 4th Jan 2011 9:44pm
nakatanenga
Germany
Open Filler neck, if you hear a "GULP" the breather is obstructed and the pump does not manage it to pump the fuel. WANTED:
SII or SIII in max 1.5k
Post #51056 4th Jan 2011 9:51pm
TC
When you say gulp, where are you hearing this, ear into the tank?
Post #51057 4th Jan 2011 9:55pm
nakatanenga
Germany
Sharp knife, cut off ear, throw in tank......won't work BUT you will hear less wining and moaning Wink
You will hear it while you open the filler neck, sure. WANTED:
Post #51061 4th Jan 2011 10:03pm
TC
Laughing
Will pass that one on..... Thumbs Up
Any more idea's?
Post #51063 4th Jan 2011 10:05pm
T1G UP
could be pump? if a cheap one was fitted, Censored in the tank etc.
or warn through fuel pipes, snapped fitting from the top of tank / pump to filter.
if the recovery man butchered the fuel lines then he'll need a new set....not cheap or easy to fit....or cheap to fit!
anyway tell him theres a monkey here for it here Rolling with laughter
Post #51071 4th Jan 2011 10:24pm
Porny
Site Sponsor
Injector seals are a very common problem...
£30 and an hour or two labour at the most.
Ian
Post #51145 5th Jan 2011 11:56am
Martin
Site Admin
Fuel pump relay faulty/burnt out contacts?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #51146 5th Jan 2011 11:57am
TC
Fuel pump was shot......
It had been replaced last month with a non OEM part.......
Cheers for everyones feedback Thumbs Up
Post #51261 5th Jan 2011 11:21pm
apmoore1976
United Kingdom 2006 Defender 90 Td5 SW Zambezi Silver
Thanks TC for asking about...
Always, always, always get geniune fuel pumps - the britpart (and others) have failure rates hitting 90%+...also airflow sensor was also shot! Injector seals were replaced a few months back (they're good for 50k miles) but as the song goes...On the road again!! Smile Previous
06 Defender TD5 CSW Silver LE
Post #52774 13th Jan 2011 3:48pm
TC
Don't listen to a word he says, I had to draw him a map from the drivers seat to the engine. The plate of metal between him and the engine only confused matters.
Go and say hello on the introduction thread Mr Moore sir Very Happy
Post #52779 13th Jan 2011 4:06pm
apmoore1976
Takes your monster offroad yet??? Whistle Previous
Post #52781 13th Jan 2011 4:15pm
TC
Up the kerb and down the kerb EVERY day..... Whistle
Post #52782 13th Jan 2011 4:18pm
