Home > Maintenance & Modifications > Driver side roof leak diagnosed. Advice to fix?
BCdefender
Canada 1999 Defender 110 Td5 CSW Orkney Grey
Hi there,
I have been dealing with a driver side water leak in my 1999 TD5 110.
After spending MANY hours resealing the gutter I have yet to solve it.
I finally removed the front of the headliner to see where it was coming in.
Take a look at the pics. Any advice on how to deal with this? Do I need to dig out the gutter and reapply sealant or is there an easier solution?
Thanks a lot.
 1999 Defender 110
2003 P38
2007 RR SC
"And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it."
My build thread: http://www.defender2.net/forum/topic47750.html
Post #510194 3rd Mar 2016 2:46am
dorsetsmith
Post #510221 3rd Mar 2016 9:02am
BCdefender
I have been through that manual more than a dozen times. I have essentially done everything in it and actually stopped quit a few leaks but this is the last one that remains.
Is it essentially saying that I need to remove the entire door seam put in the putty and tape and then re-seal the door seam? 1999 Defender 110
2003 P38
2007 RR SC
Post #510390 3rd Mar 2016 3:51pm
BCdefender
One last try then the roof is coming off...
 1999 Defender 110
2003 P38
2007 RR SC
Post #510569 4th Mar 2016 2:09am
RRUK
From that last pic have you put sealant along the entire gutter length?
What material are you using? Sikaflex or Tigerseal? 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #510615 4th Mar 2016 10:24am
BCdefender
It's Eurethane window sealant. If the silicone doesn't work I guess it's the next step! 1999 Defender 110
2003 P38
2007 RR SC
Post #520167 2nd Apr 2016 2:10am
Bps
Check the seam that runs across the roof at the front before it slope last down to the windscreen. Mine was leaking in there and running down to the drivers side. I taped it up to check and it was dry in a couple of days. I then redid it with clear sealant when it has been dry for a few days
Post #520228 2nd Apr 2016 10:54am
BCdefender
Thanks BPS I will give it a try 1999 Defender 110
2003 P38
2007 RR SC
Post #520286 2nd Apr 2016 3:56pm
dorsetsmith
second that Thumbs Up
Post #520292 2nd Apr 2016 4:13pm
Bps
Just don't use gaffa and leave it on for a long time Smile
Post #520301 2nd Apr 2016 4:46pm
nidge n
I had a leak via the alpine window seal. good luck Thumbs Up
Post #520363 2nd Apr 2016 8:07pm
What like this:
Post #524294 15th Apr 2016 7:15pm
BCdefender
Haha!! Laughing
Sort of feels like that!
More rain on the pant leg then on the roof!
Removing the roof as part of Installing Puma middle row in August. Going to remove the headliner and reseal everything so that will be the end of it! (Hopefully...) 1999 Defender 110
2003 P38
2007 RR SC
Post #524375 16th Apr 2016 2:33am
