Home > Off Topic > Name of a thing like a cam latch? Where to buy?
Cupboard
I'm looking for something to hold one edge of a board down on my work in progress sleeping platform. The idea is that the edge nearest to the engine slots in to a bit of channel, then there's about 40cm of board, the door end sits on a bit of angle, attached to a bit of box where the vertical supports fit, there's another bit of channel on the back, rinse and repeat. Like this, the black bits are metal, the brown bits are wood:
But I need something to stop the back edge flying out when I go over a bump and to stop it rattling. I was thinking a couple of cam locks, I've seen flush mount ones that have a recessed metal plate with a handle, which would stop the up and down movement.
However, when you're building something like a cold room, the panels all lock together with something that's basically a cam lock but actually pulls the adjacent panels together too. Like a cam lock but in an "j" shape where the hook of the "j" catches a peg and pulls it towards the "." of the "j". If I could use them, it would give it a load more front to back strength as all the sections would be locked together rather than being able to wobble backwards and forwards.
I've found this on US ebay:
Does anyone know what I'm talking about, what it's called and where I could get something like that from? It's on a budget so I don't want to spend a fortune Rolling with laughter
Failing that, what about just a "normal" recessed cam lock? Does anyone have a good source of them? These look about right to me: http://www.wdsltd.co.uk/product/3888/lift-...m-wds-8552
Or have I missed an obvious answer to my problems and it's not actually a cam latch at all Rolling with laughter
Thanks in advance Smile
Post #510171 2nd Mar 2016 11:36pm
An over centre latch?
Post #510185 3rd Mar 2016 12:42am
JWL
I think I can see where you're aiming but a quick look on t'internet for cam latches brings up mainly American stuff as does overcentre catches such as
http://www.ebay.co.uk/itm/STAINLESS-STEEL-...SwLzdWT2Vi
Try having a look at some of the boat chandlers sites as they bound to use simple positive "pulling" catches.
By putting that in my watch list on fleabay then looking for 'similar items' this very nice and shiny one popped up, trouble is that they seem to be all in the US of A!
http://www.ebay.co.uk/itm/FLUSH-PULL-LATCH...41a21cd657
Post #510186 3rd Mar 2016 12:47am
rustandoil
Try Car builder solutions, they may have something Thumbs Up
Post #510199 3rd Mar 2016 6:22am
Riccarton
Scotland 2012 Defender 90 Puma 2.2 HT Zambezi Silver
Would anything like Screwfix - Part No: 15443 - Toggle fit the bill? (Screwfix's picture show it being used the wrong way around Rolling with laughter ).
You could try Googling Toggle Catch if it's heading in the right direction or look at Sash Fasteners (Screwfix - 74986)?
Good luck.
Post #510219 3rd Mar 2016 8:54am
Cupboard
Some good food for thought there, thank you.
I like this idea:
I've thought about over centre catches (like those little Screwfix ones) and actually use one for my fold out table, so that's a good option too Thumbs Up
Post #510245 3rd Mar 2016 10:26am
MartinK
Or this
 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #510280 3rd Mar 2016 12:16pm
simon119
United Kingdom 2000 Defender 90 Td5 HT Rutland Red
Post #510387 3rd Mar 2016 3:42pm
Cupboard
They have some really nice stuff but how do you buy it and where are prices?
I only want a handful, I'm not building a coach!
I've bought a couple of compression latches from ebay to have a try with... I think I should be able to make them work.
Thanks all!
If anyone has any other ideas in the mean time please feel free to chip in Smile
Edit:
One thing I'd completely forgotten about (annoying considering how many of the things I've used) are flight case latches:
Post #510434 3rd Mar 2016 5:59pm
simon119
If you want to try any of the southco stuff Google the following. Will bring up a whole host of option, many including prices etc.
"southco distributors uk"
Post #510478 3rd Mar 2016 7:44pm
ickle
http://www.ironmongerydirect.co.uk/product...ass/339650
Used to use cheaper (steel) versions of these with a square key
Keith
Post #510480 3rd Mar 2016 7:55pm
excossack
How about these ?
http://www.screwfix.com/p/era-concealed-do...pack/5748g 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #510685 4th Mar 2016 2:23pm
nakatanenga
Germany
@Cupboard
Where do get these screwix fittings in your picture? WANTED:
SII or SIII in max 1.5k
Post #510695 4th Mar 2016 3:26pm
Cupboard
excossack wrote:
How about these ?
Good idea. I think I've probably found a quicker if slightly more complex solution. We shall see!
nakatanenga wrote:
@Cupboard
Depends which you mean. The first ones are "Southco C2 style compression latches" from ebay: http://www.ebay.co.uk/itm/271312170087
The second ones (the flightcase latches) are from CPC:
http://cpc.farnell.com/1/3/butterfly-latches
If you search for butterfly catch rather than butterfly latch, it comes up with some more similar ones from the same manufacturer that are cheaper. They also happen to be slightly better for what I want, and I only found them after I'd ordered. Oh well!
Post #510713 4th Mar 2016 4:39pm
nakatanenga
Germany
Hi,
meant the sliding one from carbuilders but found it.
The other ones are well known.
Peter WANTED:
Post #511578 7th Mar 2016 12:38pm
