![]() | Home > Maintenance & Modifications > 2015 Defender - Battery tender required? |
dunc Member Since: 31 Dec 2015 Location: surrey Posts: 132 ![]() ![]() ![]() |
I'm often away for extended periods - up to eight weeks at a time. I have found many cars require hooking up to a battery charger/tender to avoid the battery going flat if left for a few weeks. What is the Defender like in this regard? Anyone use or recommend using a battery charger?
have look at this
http://www.defender2.net/forum/topic42250....p;start=15 |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
I second the above statement, if you go for Check also get the "Comfort' (think that is its name) connector so you can have it permanently attached to the vehicle so you do not have to remove seat box covers etc.
![]() Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
Thanks for you comments/recommendations.
Just to confirm - do you all think it is necessary to keep the battery on the Defender on charge if left for extended periods? |
good quality battery charger will float charge as part of it fauchon i.e. Ctek
solar panel charger is good option for float charging |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2540 ![]() ![]() ![]() |
Float charging (ie Ctek for example) rather than trickle charging is preferable if you intend to leave the charger connected for long periods. I have not experienced any problems or seen any reduction in battery life since starting to use this type of charger. It will also recondition your battery as and when required. Defender 90XS SW
Whether you need one depends on what sort of other loads you've got on the battery. Split charge relay, Ultra Gauge, tracker will all use about 20mA each constantly, so that's 60mA total. 60*24=1.5Ah/day, 10Ah/week etc. which will flatten your battery in 8 weeks by themselves.
If you haven't got any of the above and just have the factory alarm going, I don't actually know how much that uses but the general consensus suggests about 30mA or 5Ah per week. Over 8 weeks that's 40Ah or about half your battery capacity. It might start, probably will assuming that's the only load and it's a decent battery. I think I'd be putting a trickle charger on just for peace of mind. |
