![]() | Home > Maintenance & Modifications > Advice on some mods |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1784 ![]() ![]() ![]() |
Depends what you want to do with it.
Electric dampers: Are you looking to lift it? Gain articulation? or make it stay flatter on the road? I ask because really, any uprating of roll bars is going to limit axle articulation and subsequently off road performance will be affected. Do you want a locking diff? Or just a stronger open/limited slip diff? |
chris d3 Member Since: 06 Apr 2010 Location: sunderland Posts: 377 ![]() ![]() ![]() |
I spend more time on road than off road. Looking for the best option for both.
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
I've heard that the difference between modes on the electronic bilsteins is too great, really choppy when in sport and too soft when in comfort mode.
I haven't had any experience with with them just what I heard. Apparently they are working on a road biased setup with different rates... 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
JellyBean Member Since: 02 Mar 2015 Location: Suffolk Posts: 142 ![]() ![]() |
I had these - the ride was far too choppy for me on the road. I doubt the set up would be at all satisfactory off road. I took them off after 6 months.
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Have you considered koni heavy tracks ?
Got them on mine, they're fine. |
jollymuckshifter Member Since: 10 Dec 2011 Location: Chester le Street Posts: 120 ![]() ![]() ![]() |
sent you a PM
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8338 ![]() ![]() ![]() |
if your looking for an ATB for the rear i have one for sale all made up ready to go, built and supplied by ashscroft, approx 500miles on it. Cheers
This one?
http://www.defender2.net/forum/topic41530.html Wouldn't the 110 in question need a P38 diff? |
sorry i had assumed it was for a 90, dont know, but nothing the post to say either way.
yes you are right a 110 would need a P30 diff casing if its a Puma or late td5 Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
That's OK then, I won't be tempted to buy it off you myself
I think I might go with Old Man Emu shocks and stiffer anti roll bars. Is anyone els using a similar set up. Not sure about springs
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2667 ![]() ![]() |
best set up i used is the alive one on there demonstrator 90 while it was still in prototyping..
they were looking into doing springs for a 110, it was a set up of bilstein b6's, uprated anti roll bars and comfort springs.. my truck has the same but sports springs, it is slightly choppy at lower speeds but excellent at cornering and at higher speeds. give them a call.. |
GSLRO Member Since: 13 May 2012 Location: Tyne and Wear Posts: 499 ![]() ![]() ![]() |
He forgot to add that he drives around with a HM roof tent fastened to the roof rack
