Home > Maintenance & Modifications > Brakes - DIY
Stiff1
Brakes - DIY
So thinking for replacing the disks and pads all round on the 2007 110 Tdci, this will be my most ambitious mechanical job on the truck to date, DO or DON'T?
Also is this a suitable set to get, thought they were vented post 2007?
http://www.ebay.co.uk/itm/111697254404?_tr...EBIDX%3AIT
Thanks in advance
Post #509020 28th Feb 2016 5:01pm
miker
Do. Get a haynes manual, be methodical and check your work once it's all back together. Pads and discs are a pretty simple job
Post #509027 28th Feb 2016 5:36pm
rustandoil
Discs and pad change is not too bad a job, hardest part is making sure that you don't get any dirt getting in the wheel bearings.
Don't forget you will need a drive flange gasket.
Post #509032 28th Feb 2016 5:55pm
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
Get a manual and have a read through is the best bit and you will also need a 52mm deep socket
Post #509036 28th Feb 2016 6:19pm
Leviathan
110 tdci front discs are vented. Ive done mine recently. Not sure about the rears.
Have a look on youtube for 'how to' videos.
Also change your brake fluid if you havent recently. My car had fsh and the fluid was black!
Post #509044 28th Feb 2016 6:34pm
rustandoil
As dave18 has pointed out, you will need a socket for the stub axle / wheel bearing nut and a new nut, some threadlock
and a suitable torque wrench
Looking at the YouTube videos is good tip as is the Haynes manual....
Post #509046 28th Feb 2016 6:56pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Haynes doesn't cover 2007 onwards but perhaps not much has changed with the brakes?
There are the LR workshop manuals online
Post #509047 28th Feb 2016 7:04pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Got mine done last week - front & rear. I bought all genuine parts from Duckworths, I think genuine is the best way to go, but expensive. I bought pattern part discs for my last Discovery and they were warped within 6 months so it'll be genuine parts from now on. Put it into my local garage to get the work done as I wouldn't feel confident enough to do such safety critical work, also I work full time and do a fair bit of O/T so wouldn't have had the time anyway. I didn't think the brakes felt too bad before, but it needed all the discs doing and obviously the pads at the same time. Glad I got it done, that should be it for a few years now.
Post #509082 28th Feb 2016 8:45pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Removing the bolts holding the caliper to the axle can be a pig.
You need a 13mm star socket, suggest you pick up a 1/2 inch star socket also, if this is your first time, consider buying new socket so the teeth are nice and sharp (defined) the thread lock on the bolts make these really tight to remove.
if you have access to apply heat, then be very careful, apply to the threaded section that is into the axle itself, not the caliber.
Andy
Post #509123 28th Feb 2016 10:28pm
Stiff1
Thank you all. Looks like I need to buy a few tools then.
What are the thoughts on the parts I listed?
Also links to a few good YouTube examples would be appreciated, don't want to follow someone who does it wrong.
Post #509170 29th Feb 2016 1:58am
jimbob7
Mintex seems a popular choice,I fitted Delphi Lockheed pads an discs,which I believe were oem suppliers at some point,(along with Delphi Lucas and Delphi AP brake calipers).Also need new caliper bolts and maybe slider pins.The fronts are vented but not the rears.As said, you need a quality 12 point socket and (maybe) a 3'+ long breaker bar to shift the occasional stubborn caliper bolt and it's worth spending a couple of quid on a quality single socket, I doubt a typical diy socket would survive.I have a few Gedore sockets,less than a fiver each.I had to move the coil springs to get easy access to the rear caliper bolts.
If you have abs,you'll need to remove the rotator ring from the inside of the rear disc,or buy new ones for about £300 (each Shocked ,I think).They can be a bit stubborn to remove as the nuts will be rusted to Censored you'll end up removing a few studs anorl and you can only fit a 10mm ring AND open ended spanner in the small gap.
Not a particularly hard job,what slows you down is stubborn nuts/bolts, front flange drives sometimes need grinding off and while it's apart clean and re-grease the bearings and calipers. Pov.spec,ftw. 2006, 110,TD5.
Post #509261 29th Feb 2016 2:13pm
