Home > My Defender > Corris 110....
Page 23 of 48 <123 ... 222324 ... 464748>
mcma1
Painted my surrounds and prepared the rear cubby...
After I test fit, it will be off for a re trim.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #509023 28th Feb 2016 5:28pm
mcma1
Been putting off this job but took my time and got a perfect fit all around.
A rough cut to start and then just used the dremel to bring it in to shape.
2014 Corris 110 SW
LS3 V8 build...
Post #509304 29th Feb 2016 5:49pm
mcma1
Subframe nearly ready to test fit.
Rear electric windows should all be in place tomorrow evening.
Started the sound proofing tonight, using Skinz, and also adding a 10mm Skinz lining kit on the roof. Badly want everything back togther now but still have a load of wiring to add... Big Cry
Also decided to add the alpine digital TV tuner, but i am going to add an external rack antena.
2014 Corris 110 SW
LS3 V8 build...
Post #509712 1st Mar 2016 9:08pm
L110CDL
Looking good Andy Thumbs Up
Clayton
Post #509781 1st Mar 2016 10:42pm
mcma1
New gears made up for the disco motors...
With the door in pieces and glass tied up out of the road I fitted Skinz over the complete inner door.
Disco motor now with new gear and plenty of lube fixed in place and worked perfectly first time, i drove it off the front motor cables for a while to get the benefit of a strong voltage.
And the door card all back on
2014 Corris 110 SW
LS3 V8 build...
Post #510437 3rd Mar 2016 6:04pm
mk1collector
So when can we place orders for the kit? Whistle Rolling with laughter Ray
My build thread
Post #510454 3rd Mar 2016 6:42pm
mcma1
Post #510470 3rd Mar 2016 7:16pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
I do enjoy looking in on your thread. So many wonderful mods that donīt come straight out of the box. Inspiring stuff. Bow down 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #510472 3rd Mar 2016 7:23pm
mk1collector
mcma1 wrote:
After 1000 cycles.... Very Happy
Rolling with laughter your kids are going to be out in the car all night to get to that number Rolling with laughter Ray
My build thread
Post #510475 3rd Mar 2016 7:32pm
mcma1
A right pain to do but hope it's all worth it, added the Skinz to the roof and then the Skinz 10mm foam...
Then had to get all the cables in for the overhead player, a lot of wiring! I have some coming down each door A post and then the TV/PS4 heading to the back, just wasn't enough room.
It is ones of those jobs that you need 4 arms, I ended up using the bottle Jack to hold it in place! Hopefully the rest will be straight forward. The biggest pain was the rear view mirror re fitting. No matter what I tried it would not go back on.... Then suddenly realised I just needed to unscrew the mounting place and fix it on top on the headlining, clicked back on in seconds then...
2014 Corris 110 SW
LS3 V8 build...
Post #510748 4th Mar 2016 6:55pm
mcma1
All back in place after some tweaks. Biggest pain was forgetting to put the back section of the head lining in first so have to take it all down and start again Big Cry
2014 Corris 110 SW
LS3 V8 build...
Post #511069 5th Mar 2016 5:52pm
mcma1
Connections made up front now and all cables neatly run.... I just need to connect up the power now and fingers crossed. Also doing a clean up in the battery box now and adding an ignition sense module which will make it handy for connecting this and the rear electric
2014 Corris 110 SW
LS3 V8 build...
Post #511342 6th Mar 2016 4:33pm
ericvv
Post #511357 6th Mar 2016 5:20pm
mcma1
Lol, I was going to take to compete dash out but I have to do the school run in the morning Andy
2014 Corris 110 SW
LS3 V8 build...
Post #511362 6th Mar 2016 5:36pm
tor-bjoern
Germany 2015 Defender 110 Puma 2.2 SW Santorini Black
mcma1 wrote:
New belts fitted... Really pleased...
really great work so far. where did you get the red belts?
Post #511881 8th Mar 2016 8:23am
