![]() | Home > In Car Electronics > Home Audio Install Advice |
jbk Member Since: 22 Nov 2015 Location: Hertfordshire Posts: 181 ![]() ![]() ![]() |
Hi All, Through the hugely helpful content on this forum, other research and youtube vids I'm thinking of and might have found the confidence to do my own car audio install on my Puma 2.2 Hard Top that arrives next week. The following is the spec that I have already or am thinking of purchasing:
Speakers - http://caraudiosecurity.com/100ac-10cm-4-coaxial-car-speakers - http://caraudiosecurity.com/focal-isn-100-...er-4-100mm HeadUnit - http://www.amazon.co.uk/Alpine-bluetooth-C...B014W9GNMI Amp & Sub - http://www.amazon.co.uk/gp/product/B0082DJ...084KD8JNL6 - http://www.amazon.co.uk/gp/product/B004A8P...RYFDOT1WO1 The speakers I've purchased already (a welcome purchase through a forum member here, you know who you are, thank you ![]() ![]() So above are the factors I've considered in making the component choices that I have and I guess I was after a bit of 'validation' or advice from you knowledgable folks before I hit the buy button and commit myself to doing this!! Secondly I'm now stalking all the youtube videos that I can to try to work out how to best fit this stuff and what additional cabling, connectors etc I need to buy on top of the main components listed above. Can you guys help me out with what materials, lengths and types of cabling, connectors etc, I need to buy to get this stuff fitted and working well? Thanks [/list] |
Thanks for the reply Barbel Jim, in researching and thinking about this audio set up I've read a fair few of your posts on the subject and the audio builds in your cars. Your cars audio set ups look great I'm sure sound great and hopefully will be where I get my car to.
I get the impression that the 10cm speakers front and rear are almost certainly going to feel a bit lacking, but as I have them already I'll at least give them a go and see what i think. It's all a matter of where you compromise I guess, in sound system quality and volume, cutting into panels or not and losing load space with sub boxes or not. When you say 3 x 3.6 RCA cables, i presume you mean 3 sets of 3.6meter long RCA cables? Thanks again for the advice. |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1412 ![]() ![]() ![]() |
![]() They will be a tad longer than needed but it will give you a bit of flexibility. My first mod would be dynamat to the rear tub and sides. Being a HT the bare wheel boxes are noisy. I used 2 bulk kits from Simon at MPS. It will cut out some of the vibration, and tinnyness ![]() Standard speakers are cheap and nasty and won't last long at higher volumes. The cone material and drivers varies the costs! Spot the difference ![]() ![]() Click image to enlarge |
Full sound proofing with dynamat or equivalent plus a CCF + MLV product planned for sure. Just still in the middle of weird feelings about covering all this lovely paint up with super sticky sound deadening!!:
![]() Click image to enlarge [/img] |
You'll only scratch it
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19750 ![]() ![]() |
Perfect paint, perfectly clean to add the Dynamat to.
Easy work, less cleaning. ![]() |
Bare fresh paint, hmmmm, I want to polish and shine it, gunk up in irremovable sticky soundproofing, ouch
![]() Weird detailing OCD, guilty ![]() Wrong car for OCD'er perhaps, yes, maybe, but yes, but no! ![]() |
So as you have no bulkhead, where are you thinking of putting the amp ??
Ha ha, yeah bl**dy good point BarbelJim!!
![]() I've figured that i'll somehow fabricate it into the under seat box or somehow site it on the floor underneath the cubby then build a plinth/box for the cubby to be remounted on top of it, perhaps with some hinge type affair. But amateur point a) is that I've not actually taken measurements on either locations and as i don't actually have the car yet (pick it up in, err, 12hrs and 14 minutes time ![]() Are my above ideas majorly floored I wonder!? ![]() ![]() |
Under the chubby should work. Off the top of my head Roughly 240mm wide and 360 long. Digital amps don't give of the heat like others. I'm sure someone else put a 5 Chanel in the seat box. Give me a mo
http://www.defender2.net/forum/topic42084....dio+review
Bit of extra reading for you ![]() |
Hmm, well linked BarbelJim and very nice set up Barney12
![]() I too have had conflicting advice re the rears, some say don't bother at all with rears you want the sound in front of you and some think rears are important as Barney12 seems to. Hmm 'chin scratching emoji'. |
