![]() | Home > Puma (Tdci) > Puma oil spec? |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512
Education is needed all over, You shuold take the lubrizol webpage or this one, I`m sure you can find in English
http://www.motul-lubricantes.com/eftm/defi...iviano.pdf Puma 110" SW ............................................................. Earth first. Other planets later |
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687
While LR specifies ACEA A5/B5 5w30 oil for the Puma, it is by no means the best oil for the engine. This will depends on where you are: climatic conditions, quality of diesel, etc.
For example, in SA we have a much warmer climate than EU & sh*t diesel, so really in SA we should be using an API CH-4/CI-4 or ACEA E5/6/7 fully-synthetic oil, viscosity 5w40. |
| LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241
I threw out that Ford oil after 3000km and never went back to it.The loose spanners in the motor have gone and now have a oil to protect my engine and not fuel cosumption. Puma 110 SW
90 V8 SOFT TOP |
What oil are you using if I may ask? |
I`m not sure, but the oil pump must be designed to deal with the viscosity given by a XXW-30 oil. Danielle (
............................................................. Earth first. Other planets later Last edited by MK on 3rd Jan 2011 4:46pm. Edited 1 time in total |
5w-50 A3/B3/B4 synthetic and changed every 6000km.It handles our heat and no cold start problems. Puma 110 SW 90 V8 SOFT TOP |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
READ CAREFULLY!!!
high HTHS OIL is ALWAYS BETTER than a low HTHS oil!!! But if I tell to the forum this and someone will have problems with the engine (not related to the oil)? May be LR look for the reason and invalidate the warranty? SO, I do not tell nothing to the forum, understand!!!!! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated
IID Pro MV License |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Why does this answer remind me of the epic film "The Godfather" |
mhmmmmmm you are wrong......
Italiani siamo Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
You mean a 5w40/50 is better than 5w30? I fully agree, it looks like LR only specified the oil that would be ideal for EU, NOT the rest of the world. I have a friend in SA who has switched to Shell Rimula HX7 and says the landy runs much more smoothly. He buys the oil and force the dealer to use this when doing the service. |
viscosity is a different characteristic than HTHS. for hot climate is better a 5W50 or a 10W60 than a 5W30 and all of these oils can have low or high HTHS. a good HTHS is better for the shear strength For educational purpose look here Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
Can you please specify the API classification and brand? |
Same happened with VW and there 0w30 longlife.Many top end failures and oil cosumption.They changed to there 5w-30 but still not good in hot climate like ours. Puma 110 SW
90 V8 SOFT TOP |
Look here: http://www.bobistheoilguy.com/forums/ubbth...amp;page=1 and related
Whereas main bearing wear increased with the viscosity below 2.2 HTHS, the con-rod bearing showed virtually no wear at the lowest tested 1.8 oil same results on my 1998-2002 tests done in SBK 4 stroke engine and offshore racing boat engine..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
| All times are GMT |
