![]() | Home > Maintenance & Modifications > Premature failure of LEDs |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
I've tried fitting 21/5W LEDs as stop/tail lights but they fail prematurely. is this because they have a permanent feed, rather than being pulsed, as in Cambus wiring?
Does anyone have a fix? Merlin |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Buy a set of Wipac units and all will be well
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1002 ![]() ![]() ![]() |
CAN bus is a data link, bulbs don't run on a data link. You can control lights with it (and much more besides), but that's not how a Defender works. You have to limit the current to an LED because unlike a bulb their resistance drops as they heat up so they don't self limit. The cheapest way is to put a current limiting resistor in but that has the obvious issue that it only works over a narrow voltage range. Cheap LED lamps do that, better ones have proper driver circuitry.
Your LEDs have most likely failed because they weren't built well, as are most retro-fit ones. They also happen to be illegal. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20980 ![]() ![]() |
Go for Wipac or RDX LED units, I have the latter. Very happy.
These are legal. |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2296 ![]() ![]() ![]() |
Ditto^
RDX fitted on mine - disproportionate improvement for the money ![]() |
