![]() | Home > Puma (Tdci) > what is this code???? |
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
Answer in this thread
http://www.defender2.net/forum/topic4311.html Bob |
| Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113
Fuel Rail Sensor In-Range High Failure:
# High Fuel Pressure. # Low fuel pressure. # Damaged FRP sensor. # Excessive resistance in the circuit. this is from google |
| yanto Member Since: 03 Sep 2009 Location: caerleon Posts: 230
Thanks for fast replys, its due to be picked up by landrover asst but if it is safe to drive there i would rather do that, do you think its ok to drive the 5 miles to dealer?
no , I did that , and they said : if you waited , its landroverīs responsibility to give you a replacement car , if you bring it to the dealer , you dont get one...
atleast here in Belgium |
I would let LR Asst. take it in if they are on their way.
Nothing worse than cancelling them and then breaking down on the way to the dealers. Bob |
Good advice there guys thanks,
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
I had this exact fault a few months ago and the dealer replaced the fuel rail under warranty
