Home > Maintenance & Modifications > Crack on roof joint, spot weld failed. Do I need to worry?
Cupboard
Where the roof changes angle on my Defender, there's a small crack. I think that's where water is coming in because the inside of the roof gets wet if you squirt it with a pressure washer, either way it's not going to help anything.
I've been pouring Captain Tolley's in, and it keeps just disappearing. Poked it yesterday and noticed how much movement there is on it, looks like one of the welds has come loose.
Do I need to worry about a loss in strength, or do I just keep pouring sealant in?
Post #507212 23rd Feb 2016 8:52am
dorsetsmith
only thing rain water leak in
Sikaflex 291 or 292 can be painted over
Post #507215 23rd Feb 2016 8:55am
Happyoldgit
A pressure washer will potentially make leaks worse. If that were mine I'd stop pressure washing, wait for the weather to warm up so the area can dry out, seal and paint. What makes you think a weld has failed? Steve.
http://forums.lr4x4.com
Post #507251 23rd Feb 2016 11:41am
Cupboard
Because when I poke it the top layer wiggles and the bottom layer doesn't, but if I poke other areas the whole lot wiggles together.
I've been having small puddles forming in the back when it rains and the wind is in the wrong direction, so I was looking for a leak whilst cleaning it. First time I've washed up there since buying it in 2014 Laughing It's only set on very low pressure anyway.
The roof inside was dry when I started washing and wet when I finished.
Post #507279 23rd Feb 2016 1:37pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
My roof had the same problem. So much fun every time. My headliner kept splashing rainwater onto my lap every time I took a turn. Rolling Eyes
Post #507287 23rd Feb 2016 2:13pm
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
I have the same thing up near the front. Touching wood I haven't noticed any leaks yet. North Cumbria Search and Rescue - Team Leader
Post #507330 23rd Feb 2016 4:42pm
Happyoldgit
If it's out of warranty then as a DIY fix I'd do what I suggested earlier with the addition of repairing suspected failed welds with blind pop rivets. Steve.
Post #507333 23rd Feb 2016 4:49pm
jimbob7
Captain Tolleys is only good for very fine cracks,looks like you need a mastic that you can paint over.As said before, Sikaflex or Tigerseal,or any non-silicon based bathroom sealant.
Run 2 lines of masking tape either side of the joint,squeeze in the sealant and finish off with your wet thumb for an undetectable finish.
If you removed the interior trim can you see where the water is coming in!! Pov.spec,ftw. 2006, 110,TD5.
Post #507336 23rd Feb 2016 4:55pm
Cupboard
Might borrow a little squirt of white Sikaflex from work and put some weights on it whilst it goes off then.
So long as that's not a structural thing that's going to come back and bite me!
Would a rivet work? I thought there was a crossmember under it where the headliner attaches but I might be wrong. Often am.
Post #507429 23rd Feb 2016 9:56pm
LR90XS2011
why not mix up some liquid araldite and work into gap, will seal and has mechanical strength to stop it growing DEFENDER 90 TDCI XS,
Post #507523 24th Feb 2016 7:40am
Cupboard
Why didn't I think of that Rolling Eyes Laughing
Thanks, that seems like an excellent idea. I've even got some in my Cupboard of Things.
Post #507882 25th Feb 2016 8:13am
