Home > Technical > Tow bar dolly for a motorcycle
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
I've been looking for a solution to occasionally transport my Suzuki Bandit behind my 90 and have seen a dolly on Fleabay.
https://www.ebay.co.uk/ulk/itm/151981830595
It seems reasonably priced and I like that it's easily fitted and removed and attaches to the tow ball rather than having a 2" receiver type towbar. Having just fitted a conventional NAS step and tow ball I don't really want the faff of changing it.
So, the question is, does anyone have experience of using this type of dolly and do motorcycles tow well with it?
Russ 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #507586 24th Feb 2016 1:30pm
miker
I'd prefer to use a small trailer personally. Also looking at the way that doesn't hinge or swivel, tighter corners could be an issue
Post #507602 24th Feb 2016 2:11pm
Try Abbastands old school company proper engineering Thumbs Up
Sorry meant Bumpstop Rolling with laughter
Post #507604 24th Feb 2016 2:13pm
salesman
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zambezi Silver
reply
firstly, after being in the bike trade for 38+ years I would say don't do it, use a trailer
safer, easier to control, and your bike gets there in the same condition as it set off in.
if you insist on using a dolly
first find out if your bike as a lift pump in the sump
this tells you it relies on the engine running to lube the gearbox.
towing the bike with the rear wheel on the floor will also spin the idle gears in the box, which wont be getting the correct lube.
so I would advise if you insist on a dolly, removing the chain before you towing to stop this
also you may find uneven wear to your rear tire, which, depending how far you tow, could result in affecting the handling of you bike.
hope that helps
barry
Post #507621 24th Feb 2016 2:59pm
McGeordie
United Kingdom 2014 Defender 110 Puma 2.2 USW Montalcino Red
A bit off at a tangent, but my mate uses one of these for his racebike, its very effective,and its beneficial if you are picking a bike up or dropping off...when you don't need it, you dismantle and drive normally.
http://motolug.com/ Sold Def 90 HT 2010...Stornaway..(SOLD in Oct 2014)
Current: delivered October 2014:- 110 USW XS.....Montalcino Red
Post #507622 24th Feb 2016 3:05pm
CarMan
I bought a MotoLug a couple of years ago - seems to me like a nice bit of kit but haven't used it yet Rolling Eyes Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #507632 24th Feb 2016 3:28pm
rustyboxx
Ideally a trailer would be great but storing it is an issue. Realistically, I wouldn't be towing the bike that many miles but it's handy to drag it along if I have to leave the 90 anywhere and need alternative transport to get around. 2015 90 XS CSW TDCi - Beautiful
Post #507687 24th Feb 2016 5:21pm
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Don't do it! Get a trailer. I bought mine from Dave Cooper in Kent.
http://www.davecooper.co.uk/trailers/trailers-for-bikes
Top man and top product. Cheers Don.
Post #507693 24th Feb 2016 6:03pm
I use an Ifor GD85 with a BumpStop Thumbs Up
Post #507712 24th Feb 2016 6:49pm
CarMan
No shares in anybody here but Russ says he's short of space and the MotoLug comes to bits without a spanner from memory and fits in the boot so they say and takes up relatively little space in the garage for sure.
Post #507717 24th Feb 2016 6:56pm
does look fine for occasional use Thumbs Up
Post #507718 24th Feb 2016 6:59pm
jimbob7
As said, gonna square the tyre off and risk of gearbox damage.
Proper trailer,ftw:
http://www.ebay.co.uk/itm/SINGLE-MOTORBIKE...SwPc9Wyzke Pov.spec,ftw. 2006, 110,TD5.
Post #507962 25th Feb 2016 12:15pm
Another way of doing it:
Post #508105 25th Feb 2016 5:02pm
Happyoldgit
The bottle jack placement in the first photo is pure class. Steve.
http://forums.lr4x4.com
Post #508108 25th Feb 2016 5:06pm
flydive
Switzerland 2015 Defender 90 Puma 2.2 Heritage Edition SW Grasmere Green
No way I could carry my bike like that
Post #508153 25th Feb 2016 7:22pm
