![]() | Home > Puma (Tdci) > defender puma turbo boost |
| martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422
3 bar max should cover it and any future mods you may make Excuse the spelling I`am better with spanners and wires.
| Zouritte Member Since: 29 Jan 2014 Location: Ain Posts: 69
Hi guys,
About the turbo gauge, do you how I can fit the sensor on a TD4? I have a gauge in mind (VDO) but still looking for the solution to fit a sensor to the turbo.. Cheers Tim |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
Obviously this isn't helpful if you want a proper dial gauge, but things like the Ultragauge will display boost pressure.
Hi Cupboard,
I already have a ScanGauge II, but i'd like to have a analog reading.. Tim |
No ideas from you guys??
| tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129
my 2.2L usually has 20 PSI
| Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334
MY2016 2.2 Puma 110 SW - running long inclines at 40 deg Celsius and 100-105km/hr - reading on Ultragauge will be 154kpa or 1.54 Bar or 22.63PSI
Tried a bit - but could never get it higher than the above. Don't know if there may be "regional" setting for maximum boost for different parts of the world. |
| Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 691
Just fitted an ultraguage over the weekend - I too am getting max boost 22.63PSI precisely! Wish I had your temperature though - it is just above zero here at the moment!
