Home > Maintenance & Modifications > Twin steering dampers
grafty99
I currently have a spare range rover classic that I'm using for parts, I've noticed they have the steering damper on the track rod as apposed to the defender setup on the steering control arm.
Could I fit the range rover track rod and bracket to enable me to fit twin steering dampers?
The reason I ask is that I am having a set of 18" wheels fitted with 285 tyres and I think the extra weight will need more damping.
Am I Barking up the wrong tree or could this mod work and be worth it?
Thanks in advance Mr. Green 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #506450 20th Feb 2016 7:21pm
Likeomg
just use one good damper...
rakeway do a modified steering damper set up but cant recall exactly how..
Post #506457 20th Feb 2016 7:58pm
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Di recieved a email yesterday about a Terrafirma adjustable steering damper, dunno if it would suit your needs ? But thought it would be worth a mention perhaps ?
Post #506465 20th Feb 2016 8:25pm
Timo K
Finland
Waste of time. You only need one that's in good nick. If you don't cope with just one, and are getting death wobble and steering judders, you have too much play somewhere else in the suspension/steering setups.
Post #506502 20th Feb 2016 9:33pm
grafty99
Thanks for the replies Thumbs Up
I didn't have any problems at all running 265s on standard alloys. I wasn't sure if the 18s with 285s would cause wobble? I'm still waiting for the upgrades to be finished so haven't driven it on the 18s yet it's just something to tinker with I suppose at zero cost to me Laughing
As for the terrafirma rtc damper, I've heard mixed reviews and assumed they were more aimed at off road setups? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #506528 20th Feb 2016 10:44pm
Bumpymike
United Kingdom 1992 Defender 90 200 Tdi SW Bronze Green
The defender unit is on the front steering bar to keep it safe when off roading - when the steering damper is fitted to the rear bar [as classics and discovery 1 ] it is more prone to damage - it doesn't take much to dent the casing and next thing the steering gets a tight spot.
Post #506777 21st Feb 2016 8:46pm
grafty99
I must say I hadn't thought of that! Although my defender is mainly a road Queen Whistle 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #506810 21st Feb 2016 9:37pm
