Home > Technical > Aligning wheel carrier
Culminator
Sold my tdi last year and bought it back 4 months later. Previous owner had rear door painted but whoever did it put the wheel carrier back on skew-whiff. I can't find any way of adjusting it and I don't remember the carrier being at such an angle. Help!
Post #506433 20th Feb 2016 6:01pm
leeds
That wheel carrier certainly looks a bit skew whiff.
Which wheel carrier is it? Is it fitted to a pre 02 door?
I would suggest you take the rear door card off and check if the door mounting plate has been reinstalled correctly.
Just noticed TDi so pre 02 door. Reinforcing ribs inside door should form a central square. I wonder if the door plate has been rotated 180 degrees? Difficult to say from photograph if that would improve the situation or not
Brendan
Post #506606 21st Feb 2016 10:26am
Culminator
Hi Brendan, yeah it's a 98 tdi. I've taken door card off and all looks undisturbed. Rotating the plate would actually make it worse. I'm sure it wasn't like this when I had it previously. If there's no adjustment available, I guess I'll just re drill the plate.
Post #506619 21st Feb 2016 11:10am
excossack
Mine is sitting quite right either (mine a 99 110), A mate fitted one to his 110 (1988) and his fits fine.
I think my issue is the two side hinge bolts are not aligned i.e with a plumb line they don't line up.
So I will be doing a similar job as you and trying to align the carrier better.
Have you got a picture viewed from the rear of the 110 ?
Mine is a Bearmach carrier 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #506635 21st Feb 2016 12:36pm
leeds
Which make of wheel carrier is it?
Have a look here which shows fitting of a Bearmach wheel carrier. The Bear mach wheel carrier has a small dog bone connecting door to main arm.
The Safari Equip has a longer dog bone
Britpart DA2232 fitting instructions here has a piston between door plate and main arm
So what I am thinking is that the door plate is on the wrong way and that a jointing piece is missing. However not knowing make of wheel carrier makes it more difficult to work out what might be wrong/missing
Brendan
Post #506853 21st Feb 2016 11:20pm
Culminator
Hi Brendan, thanks for posting that. Looks like I have the Bearmach one and in the last pic it shows the carrier at roughly the same angle as mine, so maybe it's ok and I just didn't remember it was like this before!
Post #507159 22nd Feb 2016 11:14pm
