Home > Technical > New defender not slowing down on over run.
daedalus
New back to LR's after a long hiatus so I'm not sure if this a fault or a trait. I have a new 110 Defender which when you take your foot off the accelerator doesn't slow down, it runs on at whatever the throttle setting was, a dab on the brakes knocks it off and you then get the natural slowing process. It's like unwanted automatic cruise control!
thoughts?
thanks
Post #503474 11th Feb 2016 3:08pm
jimbob7
Sticky/frozen throttle cable.....do these modern new things even have cables,dunno!Does the throttle stick when your parked up (out of gear)?? Pov.spec,ftw. 2006, 110,TD5.
Post #503475 11th Feb 2016 3:15pm
daedalus
Hi, Thought of that and no it doesn't.
Post #503476 11th Feb 2016 3:18pm
Happyoldgit
No cables for a long time. If it's new then take it back to the dealer. Steve.
http://forums.lr4x4.com
Post #503479 11th Feb 2016 3:28pm
mk1collector
Are the mats getting stuck in the pedal anywhere? Ray
My build thread
Post #503486 11th Feb 2016 3:42pm
JOE_130
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Java Black
I would suspect mechanical issues with the pedal actuator. The pedal has a twin "rail" system that uses two different resistances travelling in opposite directions as the pedal moves as a fail safe to avoid issues like this or unexpected acceleration.
If its new just take it back to the dealer or preferably get it recovered by Land rover assist (you should have a few year's free cover with a new vehicle). The dealer should take the issue very seriously as its a safety critical concern. Its certainly not a "trait" of the 2.2
Post #503493 11th Feb 2016 4:19pm
Cupboard
Does it stay on mock cruise control for an extended period?
My 2.4 does continue for a bit after I let off the pedal but I'm pretty sure that's just reverse turbo lag, it certainly feels like it is. The turbo is a funny beasty, first time I gave my mum a lift she thought there was a police car behind us the noise it makes!
Post #503666 11th Feb 2016 10:03pm
CRC@LandRover
Verified Account
Verified Account
Hi daedalus
Thank you for your post.
I am sorry to learn of the concern that you have described and I would be happy to assist you in investigating this.
In order for us to investigate or comment on the concern with your vehicle, it would need to be physically inspected by your local Land Rover retailer who will then be able to confirm their findings. Due to the nature of the concern, a road test with a retailer technician may be beneficial.
If you would like to make me aware once your vehicle is booked in with your retailer and provide me with your vehicle and contact details via PM, I will be happy to see how we can assist.
Regards
Ryan
Post #505493 17th Feb 2016 3:02pm
Solihull Boy
Hi all,
My 2011 does as cupboard says, if you change from a wide throttle opening onto the brakes swiftly, the engine takes a good second or so to transfer from full power to overrun, which can be a bit disconcerting.
The turbo makes a great noise though. The first time my wife travelled in the 110 she kept telling me to look out for the fire engine that was approaching. When I told her it was just the turbo she said, 'well in that case you'll have to get rid of that because I can't cope with that awful noise on a long journey'!!
The issue I have with mine that the dealer has been unable to sort, is that it 'shunts' when cold and travelling downhill with just a whiff of throttle. It seems that the correct signal is not being sent or received some where in the fly by wire throttle, and it is as though the throttle is on and then off sharply which only get's worse and worse till I depress the clutch or apply throttle to stop the shunting.
Regards
Ged Retired from the day job and now self employed - what a life!!
Post #505692 18th Feb 2016 1:08am
LRNZ
New Zealand 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
Hmm my one does this too and I assumed it was normal. Might have to get it checked out.
Post #506351 20th Feb 2016 10:33am
integrale
New Zealand
There are multiple posts about this. Search 'rev hang'. It appears to be very common. My new Heritage does it - badly. BAS offer a solution but warranty implications may concern some owners.
Post #506356 20th Feb 2016 10:57am
Fatboy Slim
Wales
This has been a problem for some since the introduction of the 2.4. Could be me but some seem to do it worse than others. Defiantly software related, I have no idea why defenders do it but never experienced it in a transit..........
Post #506365 20th Feb 2016 11:38am
