![]() | Home > Td5 > Td5 Misfire |
| WillH Member Since: 16 Feb 2016 Location: Cornwall Posts: 17
Hi guys
Fairly new here so hopefully this is in the right section. I recently discovered that the ally intercooler in my Td5 90 had cracked open on one of the welds. Having taken it out and had it repaired, I put it back in this evening and it now appears to have a misfire and flat spot when under acceleration. Does anyone know how this would have caused this? Or is it likely to be something else and its just a coincidence? From what I've been told by the previous owner its had a Td5 Alive remap and I've also found that it has a Td5 Alive boost box fitted, as well as the bigger intercooler. Thanks Will |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
oil red plug ECU under driver seat
| Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006
Check your turbo waste gate to see if it's siezed.
I'll have a look at both of them. Cheers!
Turns out the waste gate was seized. There was also a small amount of oil in the plug between the injector harness and the rest of the loom so I've ordered a new harness. Thanks guys!
