Home > Maintenance & Modifications > Tightening Battery Terminals
Page 2 of 2 <12
Landrover's been fitting those nasty things for quite a while now, my '02 Disco 2 and my '07 DC both had them from the factory. They don't have them any more!
Horrible things, I have no idea why they were introduced, but I imagine that cost had something to do with it.
Post #506158 19th Feb 2016 4:26pm
dorsetsmith
as blackwolf see about them also id repeat the words of an army engineer said but id be bar from the forum Rolling with laughter
needless to say he removed them thou then in the ditch and fitted replacement ones Thumbs Up
Post #506165 19th Feb 2016 4:47pm
Leviathan
Yes they are the ones pictured. See below.
And
Looking at them in more detail I can see how they are closed up and would benefit from some Dremel action. They are a crappy design though.
i dont want to cut them off because the +ve terminal has an incorporated fuse holder.
Can I leave the battery disconnected for long periods without affecting any electronics?
Post #506208 19th Feb 2016 7:24pm
Caterham
Luck or otherwise I don't know but I disconnected just the earth while did the dremmel business which didn't take too long as it a soft metal and all was fine. I think even if it was an hour or more it wouldn't be a problem.
Good luck.
Post #506210 19th Feb 2016 7:28pm
Leviathan
I'm leaving mine off overnight as Ive painted the battery tray!!
I replaced the battery on an E class Merc I once owned and phoned the main dealer to ask if I could leave it off while I took it to match up a new one - 'no problem' said the dealer.
When I eventually got a new battery the error lights lit up all over the dash. I had to pay £100 to the same dealer to reprogram my car!! When I complained he said that he thought I meant for the few minutes it takes to swop over. Evil or Very Mad
I'm assuming there isnt all that to worry about on my poverty spec Puma?
Post #506217 19th Feb 2016 7:57pm
Good question - maybe one of these might solve the issue?
http://www.amazon.com/12V-Automotive-Setti...=leosm1-20
Post #506227 19th Feb 2016 8:21pm
Leviathan
I'm going to find out the hard way cus its going to be off for minimum 24 hours Confused
Post #506309 19th Feb 2016 11:16pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Morning, I had mine disconnected all day when I was adding my twin battery solution so you should be fine.
Post #506338 20th Feb 2016 8:55am
When did JLR discontinue radio codes?
Post #506375 20th Feb 2016 12:04pm
Leviathan
Just to wrap this up.
Caterham I did as you and sliced a new groove with my Dremel. I also noticed that the battery post had a ridge made by the clamp that stopped the clamp sitting fully down.
I filed off the ridge and tapped the clamp down. It went on deeper and now is as tight as a crab's ass at 50 fathoms. Mr. Green
Also no problems with the battery being off for 24 hours.
Another job ticked off the list.
Thanks again to all contributors.
Post #506414 20th Feb 2016 3:51pm
Caterham
Tip top
Thumbs Up
Post #506441 20th Feb 2016 6:39pm
Page 2 of 2 <12
